Forum Malfunctions (Intel Mobo)
Status
Not open for further replies.
cisco guy
There is a thread here about reply taking +5 sec which was closed as "solved"
Its not solved and many are double posting by mistake (Intel mobo)
Heres what happens:
On posters FIRST quick reply action, it sits there for a while, then the rotating icon appears, then it goes dead, then the "cant repost before 33 seconds" error appears. But if you go back to original page and reload it, the post appears. This becomes extremely annoying after a while. At some point it stops doing it and it becomes instantaneous again.
It just happened to me right now as I tried my first Intel mobo quick reply
On this reply it was back to working again as expected.
If you look at these two posts you will see Mac has just done it
http://hardforum.com/showpost.php?p=1037303867&postcount=2839
http://hardforum.com/showpost.php?p=1037303874&postcount=2840
We've been experiencing this problem in a few lengthy Genmay threads, too. Apparently it's a vB issue that seems to happen around the 2500 post mark.
Best thing to do is once you submit your post just wait a few minutes and it will be there. It's easy to avoid the double posting if you just realize that your post went through and there's no need to try to submit it again.
Status
