Fortron 700w SLI worth it ?
jerramaya
hey guys just a quick question
should i go for Fortron new 700w SLI PSU ?
LINK
it has +12V@15A not 18A will that effect coz i think it will. and if not then why not ?
Not worth it - I would suggest grabbing the 600W instead if you want one of these. It already has more than enough power for most rigs. Most non SLI systems won't even use all 4 12v rails
jerramaya said:
so 15A instead of 18A also matters
Only for a dual 12v unit when you're trying to power SLI video cards from the same 12v rail as the drives are on, or when trying to run a high end P4. The quads are a little better prepared - in this case, the PCI-E connectors are on 12v2 (shared with half of the 8 pin EPS connector) and 12v4 so they're seperated from the drives on 12v3.
A P4 might need 12v1 and 12v2 combined to overclock well.
I'm more concerned about the rediculous prices on the Fortron quads than whether or not they'll run things.
