I have plenty of HDD space as is to try it with.
bexamous probably has an OCZ Vertex 30gb because its really 32gb and 29.9gb formatted.No, 32 Gb are really 30 GB.
That would be awfully tight.
http://blogs.technet.com/askcore/ar...and-windows-vista-and-why-is-it-so-large.aspxAll of the components in the operating system are found in the WinSxS folder – in fact we call this location the component store. Each component has a unique name that includes the version, language, and processor architecture that it was built for. The WinSxS folder is the only location that the component is found on the system, all other instances of the files that you see on the system are “projected” by hard linking from the component store. Let me repeat that last point – there is only one instance (or full data copy) of each version of each file in the OS, and that instance is located in the WinSxS folder.
http://en.wikipedia.org/wiki/Featur...ication_isolation_.26_side-by-side_assembliesA common issue in previous versions of Windows was that users frequently suffered from DLL hell, where more than one version of the same Dynamically Linked Library (DLL) was installed on the computer. As software relies on DLLs, using the wrong version could result in non-functional applications, or worse. Windows XP solved this problem by introducing side-by-side assemblies. The technology keeps multiple versions of a DLL in the WinSxS folder and runs them on demand to the appropriate application keeping applications isolated from each other and not using common dependencies.
