Former Mac Dev Slams Apple's 'Bloated' Pricing
I swear I saw on Engadget yesterday that the new MBP has usb3, thunderbolt, and I'm assuming ddr3 1600
it does. the guys complaining are referring to the Mac Pro (the workstation not the portable)
I'm a little late to the game here, but isn't this mostly true with most Apple products?
I mean, look at the iPod Touch as an example...$300 still for 32GB...800mhz CPU, 512MB RAM...you can get a used EVO 3D for like $200 or less on eBay that has dual 1.2ghz CPU's, 1GB RAM, 8GB built in all with the same resolution screen, better features, better camera, 3D screen etc...and this is just ONE example of the multiple cellphones/PMP's that are available for way cheaper.
GRANTED the iPod Touch I'm sure hasn't been selling like hot cakes lately, but the point still holds firm...the iPod Touch is obviously still wayyy overpriced as is most of Apples line up IF you don't:
A; Care about iOS
and
B: Aren't a Apple fanboy/have a uncontrollable attraction to cheap aluminum housings.
I'm NOT a Apple hater...but 90% of the time I can't help but think "fuck you Apple"...its obvious to me that innovation has gone out the window and all they REALLY care about now is just money and keeping their drones to continue buying their products.
cheap aluminum housings? lol. you apparently dont understand the engineering that went into those "cheap housings".
Well, what I meant by that is the fact that they use low-grade soft aluminum, hardly anything anodized or air-craft grade.
A knife made out of their aluminum would be dull by the first cut.
Thats what I meant by "cheap"...hell, thats probably why they use it cause its probably cheaper than using plastic molds and I doubt any half decent CNC machine would need blade swaps nearly as much...food for thought!
It never ceases to amaze me how often people will spout off bullshit without doing basic, rudimentary research. It took me about 5 seconds to google "macbook aluminum aircraft grade"
By using aluminum to create the cases for its electronics, Apple has made a significant contribution to its environmental sustainability goals. Apple adopted the use of aircraft-grade aluminum back in 2007 when Apple CEO Steve Jobs penned a letter pledging for a greener Apple. The company has found remarkable success thanks to the switch, achieving a 66.4 percent recycling rate in 2009. Numbers are still being calculated for 2010, but Apple has set a goal of 70 percent for 2010-2015.
Apple measures its recycling rate by calculating the total weight recycled in a given year and then dividing that by the weight sold seven years earlier. When Jobs first announced Apple’s sustainability goals, he said that the company would raise its recycling rate from 9.5 percent in 2006 to 28 percent in 2010. Needless to say, the company far surpassed its goals. Due to the high increase, Apple Insider reports that there are rumors that the next-gen iPhone could return to its original aluminum casing.
The CEO of aluminum company Alcoa, Klaus Kleinfeld, told Apple Insider that aluminum is “infinitely recyclable,” and that 75 percent of all aluminum created since 1888 is still in active use today. Recycled aluminum requires a mere 5 percent of the energy needed to produce new aluminum, and the process produces 95 percent less greenhouse gas emissions.
Alcoa is projecting a large increase in the amount of aluminum used in electronics, citing the company’s new 10 percent stake in e-waste collector Electronic Recyclers International as a reason.
When the iPad 2 came out, many (including Inhabitat) questioned how green the product actually is. A lot of the discussion focused on whether or not iPad users would convert to reading all magazines and books on the reader. But given the benefits that Apple has found just from using aluminum in its electronics, it’s easy to see that Apple’s aluminum encased electronics are definitely greener than their plastic-covered counterparts.
-- http://inhabitat.com/apple-surpasse...-aircraft-grade-aluminum/macbook-kazuho-okui/
because presumably if you're a professional developer you'd want to be able to sell your product
Because you can not sell anything produced on a hackintosh because you are breaking apple's eula?
that would be the gist of it, yes. presumably non-shady developers only use properly licensed software.
Just wanted to make sure I understood the point you were making. I can have a good laugh now thank you.
MacBook Pro is not the same as Mac Pro
MacBook Pro:
Mac Pro:
Can be missed if you read quickly, I know.
