Viper87227
- Jun 2, 2004
I was running a "temporary solution" windows Xp until my XP Home arrived, and last week my install got corrupted for some reason or another. Windows couldnt find two files. I got XP Home last night, and did a clean format of my windows partition and reinstalled XP Home. After I did that, my system is running like hell. For starters, I have all but lost the ability to overclock. Before I was able to get 260x10 stable, now, 230x10 is causing constant rebooting. My graphics card is also having issues. Games with pause ever 20 seconds or so. I had to unclock the card by 100mhz to make it stop, and I still get some really bad graphical glithers. I checked my temps and heat is not the problem. I immeadily thought PSU, but I just dont see how it could be. PCP&C TurboCool 450 is what I have, its a damn good PSU. The 3.3 stayed at 3.22. 5 stayed at 4.9. 12 usually hung aroudn 11.90, the lowest I saw it drop was 11.54, and it was breif. I just cant understand whats happening, the only thing I did in between the installs was move the location of the computer about ten feet and add a 2005fp, neither of which could be factors. I installed windows twice, which should rule out a bad install. What could be causing all these problems, any ideas would be appriciated.
