For HTPC, which is a better OS to use, XP or Vista?
Discussion in 'Home Theater PCs & Equipment' started by EarthBrain, Sep 5, 2008.
  1. EarthBrain
    EarthBrain Limp Gawd
    404
    Sep 5, 2007
  2. bladeiai
    bladeiai [H]ard|Gawd
    1,119
    Dec 26, 2004
    I used xp 2005 MCE for a couple years and then made the move to vista MCE when I upgraded my HTPC a few weeks ago, I would say I much prefer Vista to XP
  3. EarthBrain
    404
    Sep 5, 2007
    Why is it better? Is it because of the better interface..or smoother framerate, etc..?
  4. StorageJoe
    StorageJoe Limp Gawd
    460
    Jun 14, 2005
    Vista is more resource intensive, but you do get access to DX10 and some other goodies. If it is strictly a HTPC, I'd go with one of the linux distros like ubuntu running MythTV as a front end. It's free, less of a resource hog, and overall makes a better HTPC. If it's being used as a PC hooked to your HT, then Windows is the way to go. If you have an XP license, I'd stick with it, but if building from scratch Vista is really the way to go.
  5. bladeiai
    1,119
    Dec 26, 2004
    Looks nicer, I like the design and layout of the interface better. more responsive (no pauses after pressing buttons). I also like the management of music and pictures better.
    I would also recommend getting my movies if you plan to archive movies and DVDs.
  6. 3rdshiftdj
    3rdshiftdj Limp Gawd
    432
    Jul 14, 2008
    get vista and tweak it and it'll run just as fast as server 08 w/ media center
  7. ambientZ
    ambientZ [H]ard|Gawd
    1,466
    Mar 1, 2004
    Vista Home Premium includes MCE which is pretty nice and i believe has more capabilities than XP MCE.
  8. l3ender
    l3ender [H]ardness Supreme
    5,339
    Jan 1, 2007
    Vista Media Center looks and feels really nice, so I'd say Vista.
  9. Grentz
    Grentz [H]ard as it Gets
    17,118
    May 5, 2006
    Vista MCE runs a lot nicer from what I have seen in limited using of it vs. MCE 2k5.
