Folding
dbu8554
So I got the client I am now folding, is there a way I can make it stop automatically when I am using programs that need processing power or do I gotta do it manually just wondering thanks alot.
:D
The CPU Client gives back the cycles as needed as they only use the idle cycle meaning they'll use whatever you are not using. In the end it'll always show 100% CPU usage but don't worry. If you need the processing power, the client will give it to you automatically.
what client are you using?
generally has two settings, LOW and IDLE, so anytime u need more processing power you´ll get it automatically
Which client are you running?
If it's the standard client or the SMP it should release cycles as needed... the new GPU client may be a bit sketchy but the others should have little to no impact on performance.....
And thanks for folding..... we're all glad you've joined the [H]orde:)
/beers and tamales to you man....Fold On!!!!!
Like the others said, it's made to be invisible. Just let it run.
yeah just fired up some games didnt notice a difference, so install this on a few more PC's and I will be set to bad my machine sucks I would like to post some good numbers.
Borg a friend or 2 compys ;)
