dr_dirtnap said:How does receiving/sending work units in batches work for dialup users? I have seen the option installing the clients and never used it. Might be something to look into.
Or as SmokeRngs suggested, you can just run multiple instances of F@H in different folders so when one WU is done, the other instances will get more CPU time.
relic said:so that it says <driveletter><path>fah500-console.exe -svcstart -local
