Folding Problem
apHytHiaTe
I use F@H 5.02, the graphical one, and now it's not folding. It is either saying "Attempting to send results" or "Attempting to get work packet" and it won't ever go to the folding part any more. I have restarted the proggie, but it won't start folding. It's been doing this for the past couple of days, and i want to get things rolling again.
Also, i'd like to switch to the text client, but i'm not sure where to start. I'd like for it to run in the background no matter who's logged in. My mom and i use different logins (winxp home) and we often have two on at once. I'd like to be able to run F@H when no one is logged it, for greater performance. Is that possible? What do i need to know?
the 5.02 console version has a service installer on it... I believe that it starts when the PC is booted, and will run in the background, no matter the user... and follow the instructions here to get started...
I can't help you as to why the graphical one won't work, I've never used it... If it still happens with the console version, I'd check with the settings to see if ports are blocked or the usual "can't get to ____" net problems....
Keep on Folding!!
I'm trying the textual one right now....
Code:
--- Opening Log file [December 28 02:49:37]
# Windows Console Edition #####################################################
                       Folding@Home Client Version 5.02
                          [url]http://folding.stanford.edu[/url]
Launch directory: C:\Documents and Settings\Owner\Desktop
Executable: C:\Documents and Settings\Owner\Desktop\FAH502-Console.exe
[02:49:37] Configuring Folding@Home...
The program will continue in non-service mode now, working in C:\Documents and Settings\Owner\Desktop.
The next time the computer is starts up, you should see work automatically
continue there. Note that when this service is running, you should not try
to manually run F@H from that directory at the same time.
[02:52:21] - Ask before connecting: No
[02:52:21] - Use IE connection settings: Yes
[02:52:21] - User name: apHytHiaTe (Team 33)
[02:52:21] - User ID: 9BB552913FFF771
[02:52:21] - Machine ID: 1
[02:52:21]
[02:52:21] Work directory not found. Creating...
[02:52:21] Could not open work queue, generating new queue...
[02:52:21] + Benchmarking ...
[02:52:24] - Preparing to get new work unit...
[02:52:24] + Attempting to get work packet
[02:52:24] - Connecting to assignment server
[02:52:25] - Successful: assigned to (171.65.103.155).
[02:52:25] + News From Folding@Home: Welcome to Folding@Home
[02:52:25] Loaded queue successfully.
[02:52:28] + Closed connections
[02:52:28]
[02:52:28] + Processing work unit
[02:52:28] Core required: FahCore_78.exe
[02:52:28] Core not found.
[02:52:28] - Core is not present or corrupted.
[02:52:28] - Attempting to download new core...
[02:52:28] + Downloading new core: FahCore_78.exe
[02:52:29] + 10240 bytes downloaded
[02:52:29] + 20480 bytes downloaded
[02:52:29] + 30720 bytes downloaded
[02:52:29] + 40960 bytes downloaded
[02:52:29] + 51200 bytes downloaded
[02:52:29] + 61440 bytes downloaded
[02:52:29] + 71680 bytes downloaded
[02:52:29] + 81920 bytes downloaded
[02:52:29] + 92160 bytes downloaded
[02:52:29] + 102400 bytes downloaded
[02:52:29] + 112640 bytes downloaded
[02:52:29] + 122880 bytes downloaded
[02:52:29] + 133120 bytes downloaded
[02:52:29] + 143360 bytes downloaded
[02:52:29] + 153600 bytes downloaded
[02:52:29] + 163840 bytes downloaded
[02:52:29] + 174080 bytes downloaded
[02:52:29] + 184320 bytes downloaded
[02:52:29] + 194560 bytes downloaded
[02:52:29] + 204800 bytes downloaded
[02:52:29] + 215040 bytes downloaded
[02:52:29] + 225280 bytes downloaded
[02:52:29] + 235520 bytes downloaded
[02:52:29] + 245760 bytes downloaded
[02:52:29] + 256000 bytes downloaded
[02:52:29] + 266240 bytes downloaded
[02:52:29] + 276480 bytes downloaded
[02:52:29] + 286720 bytes downloaded
[02:52:29] + 296960 bytes downloaded
[02:52:29] + 307200 bytes downloaded
[02:52:30] + 317440 bytes downloaded
[02:52:30] + 327680 bytes downloaded
[02:52:30] + 337920 bytes downloaded
[02:52:30] + 348160 bytes downloaded
[02:52:30] + 358400 bytes downloaded
[02:52:30] + 368640 bytes downloaded
[02:52:30] + 378880 bytes downloaded
[02:52:30] + 389120 bytes downloaded
[02:52:30] + 399360 bytes downloaded
[02:52:30] + 409600 bytes downloaded
[02:52:30] + 419840 bytes downloaded
[02:52:30] + 430080 bytes downloaded
[02:52:30] + 440320 bytes downloaded
[02:52:30] + 450560 bytes downloaded
[02:52:30] + 460800 bytes downloaded
[02:52:30] + 471040 bytes downloaded
[02:52:30] + 481280 bytes downloaded
[02:52:30] + 491520 bytes downloaded
[02:52:30] + 501760 bytes downloaded
[02:52:30] + 512000 bytes downloaded
[02:52:30] + 522240 bytes downloaded
[02:52:30] + 532480 bytes downloaded
[02:52:30] + 542720 bytes downloaded
[02:52:30] + 552960 bytes downloaded
[02:52:30] + 563200 bytes downloaded
[02:52:30] + 573440 bytes downloaded
[02:52:30] + 583680 bytes downloaded
[02:52:30] + 593920 bytes downloaded
[02:52:30] + 604160 bytes downloaded
[02:52:30] + 614400 bytes downloaded
[02:52:30] + 624640 bytes downloaded
[02:52:30] + 634880 bytes downloaded
[02:52:30] + 645120 bytes downloaded
[02:52:30] + 655360 bytes downloaded
[02:52:30] + 665600 bytes downloaded
[02:52:31] + 675840 bytes downloaded
[02:52:31] + 686080 bytes downloaded
[02:52:31] + 696320 bytes downloaded
[02:52:31] + 706560 bytes downloaded
[02:52:31] + 716800 bytes downloaded
[02:52:31] + 727040 bytes downloaded
[02:52:31] + 737280 bytes downloaded
[02:52:31] + 747520 bytes downloaded
[02:52:31] + 757760 bytes downloaded
[02:52:31] + 768000 bytes downloaded
[02:52:31] + 778240 bytes downloaded
[02:52:31] + 788480 bytes downloaded
[02:52:31] + 798720 bytes downloaded
[02:52:31] + 808960 bytes downloaded
[02:52:31] + 816738 bytes downloaded
[02:52:31] Verifying core Core_78.fah...
[02:52:31] Signature is VALID
**SNIP**
[03:12:55] *------------------------------*
[03:12:55] Folding@Home Gromacs Core
[03:12:55] Version 1.70 (October 24, 2004)
[03:12:55]
[03:12:55] Preparing to commence simulation
[03:12:55] - Looking at optimizations...
[03:12:55] - Created dyn
[03:12:55] - Files status OK
[03:12:55] Couldn't v3Decompress
[03:12:55] - Fatal: Could not decompress work unit data.
[03:12:55] Error: Could not open work file
[03:12:55]
[03:12:55] Folding@home Core Shutdown: FILE_IO_ERROR
[03:12:59] CoreStatus = 75 (117)
[03:12:59] Error opening or reading from a file.
[03:12:59] Deleting current work unit & continuing...
[03:13:03] - Preparing to get new work unit...
[03:13:03] + Attempting to get work packet
[03:13:03] - Connecting to assignment server
[03:13:04] - Successful: assigned to (171.65.103.152).
[03:13:04] + News From Folding@Home: Welcome to Folding@Home
[03:13:04] Loaded queue successfully.
[03:13:04] - Error: Attempt #1  to get work failed, and no other work to do.
             Waiting before retry.
I have all the stuff located on my desktop, is that a problem?
Which are you using, the console or the graphical version?
If you are still using the graphical version, I believe the newest version for that is 5.03 and you mentioned you were using 5.02. I believe there were some problems with that one that 5.03 fixed.
The console version is at 5.02 though. It gets a bit confusing at times when I go to the site to download a copy for another system. I always see the 5.03 and think they updated the console version when it is juse the graphical version.
I'm afraid I can't help you on the graphical version since I have only used the console. If you are still using the console version and it will not crunch a unit or won't get a new one. You can just delete the folder and start over with a new copy. I would suggest downloading a new copy of the console first in case there was something wrong with the original download. Also, if you have the console configured as a service, make sure you run the program with the -configonly flag and have it uninstall the service before you delete the folder.
The main reason I have problems with getting packets is due to firewall issues.
I checked on my dually PII 266 box and noticed that one of the processes wasn't running and did a little looking into it. I obviously have it set to run timeless WUs since I don't think it would make the deadline for about anything else and it couldn't get a WU. It had been trying since probably 3 am to get one. I looked on Stanford's server stats page and the reason it wasn't getting a WU was because the server it was trying to connect to seemed to be overloaded. This is something I have a tendancy to forget about. It's also why I don't install folding as a service on my own personal boxen. With the window sitting there it's a lot easier to see if the client is having a problem connecting and what server. I know I can pull it from the log file but it's just easier to bring the window up.
Thanks, I guess I was pissing in the wind again, as its going. Must have been server overload. I find it helps just to restart.
Also, in roague_jedi's script thing, do I have to set the ip address correctly? I know that people use that script to borg, and it seems that they wouldn't be changing the client file on the fly, but apparently that's necesary. I thought it was something you could just stick it, and it would go.
Where is there an IP in the autoinstaller? I didn't think there was one...
From teh client.cfg thinger.
[settings]
username=apHytHiaTe
team=33
asknet=no
bigpackets=yes
machineid=1
local=29
[http]
active=no
host=192.168.1.2
port=8080
usereg=no
usepasswd=no
Sooo.... If I put this on a pendrive and had the client.cfg all fixed up, i could just pop it into any box and it would autoinstall f@h?
again from the client.cfg thinger.
[http]
active=no
host=192.168.1.2
port=8080
usereg=no
usepasswd=no
:p
that's there on purpose. if there needs to be a proxy set (say in a work environment) then the setting needs to be changed. otherwise that can be left alone and it won't hurt anything.
and hypothetically, yes. (it is untested by me as of yet)
OK, so since the ip doesnt matter if the proxy is diabled, does the machineid or local matter?
it shouldn't - are you having problems again? if so, just delete the client.cfg and run fold -configonly & restart the service. That should fix it.
Nope, no troubles, I was just curious about the client.cfg thing for borging purposes.
EDIT: Thanks soo much guys for all your help. Fold on! w00t! :D
MachineID is only important if you are running between two to eight copies on the same box then every one needs to be different.
Local is just the number of work units done by that client.
Luck.......... :D
Thanks Tigerbitten!
I probably would have gotten flamed on other forums for asking such n00b13 questions, but you guys were great. I guess all you want out of me is my cycles ;)
G\L and Happy B0rging!
No, it's not all we want. Well, that's what most of us want. The Moose over in the corner checking you out could be a different story though. :eek:
