chrisf6969
- Oct 27, 2003
IF you could have whatever you wanted with an upcoming official (non-beta) release what would you want?
Mine would be:
1. SMP support (currently its only beta)
1b. would throttle to fewer cores if you were using your computer, and use all available cores when idle. ie: with a quad, maybe use 3 cores when you're using the computer normally, maybe only 2 if you were gaming. And on a normal dual core, only use 1 core while you're using your PC for surfing, etc.
2. Show actual graphical representation of the molecules its folding (I know this is a big stretch and would probably waste too much resources)
3. Show a status % bar in the taskbar, similar to a battery meter icon in the taskbar on laptops.
4. Show how many points the WU you're doing is worth. (I know they have other apps like foldingmonitor, or whatever that do this, but why not have it integrated one day)
5. Better stability. I mean this shouldn't really need to be on a wish list, but I find there's times where it hangs or shuts down/errors at the end of a work unit while trying to get a new one, etc. It might be b/c I used like the 6.x SMP version instead of the 5.9x version, etc.
Mine would be:
