BillR
Born Again Cynic
- Feb 17, 2002
Folding and networking
I have been playing with this for a while now and have come to a few conclusions.
If you are running Windows or Linux and you are using a router you may well be costing yourself a notable point loss.
By default almost everyone uses DHCP when they set up a home network, face it, it’s easier that way. The problem comes about when you reboot, or have a momentary network dropout. This applies primarily to the SMP client and particularly with dual SMP clients.
If perchance you get or create a glitch and your router reassigns a new DHPC address to your machine this can cause the client to appear healthy, your cursor will blink in the folding window if you have it open, but folding may well have stopped.
If you are running VM it doesn’t seem to be an issue, however if you are running dual SMP clients in native windows it can and usually will shut you down.
The answer is pretty simple; assign each machine a static address first then turn off DHCP in your router.
One thing to keep in mind is wireless. I use a Linksys router and by default is starts its DHCP addresses at 192.168.1.100 and works it way up from there. I started my static addresses at 192.168.1.20, next 192.168.1.21, 22. 23 and on up the line.
For my laptop, or a customers laptop I enable DHCP but allow only one or two assignable DHCP addresses.
Thought it was an observation some might find useful
Fold on
Fold on
