no no, they have fold out as well. you remove the side panel (one showing back of motherboard) and you can flip the tray down, i know i what he's talking about.
although, i've only seen it once, it was from a full size generic case. years ago.
umm... i want to say it was a foxcon??? case? i have no idea, i'm sorry.
Didn't the G4s do that? Or G3s or whatever the hell that was. I'm not a mac guy. I've never seen a pc case that could do that. Although it sounds like a pretty easy mod.
alot of the old enlites had a similar set up to this as well (totaly removeable useing spring loaded latch. Personaly i liked that set up better than a removeable mobo draw. Only draw back was the cards had to be installed after the tray was locked back in place.
I have that case right now. Its pretty cool in a lot of respects, but really crappy in others. I *do* really like the fold out mobo tray, however, the side panels are very tough to get on once you have taken them off. Case is kind of flimsy too...
Other than that, I really like the case. Lots of room.
