Flashing bios
Ok, so i need to know how to flash my bios correctly, because it looks like im not doin it right. I have an ABIT AN8, and i downloaded the bios files. Then i went to their site and i read instructions on how to flash. It says to create a boot disk and then make another disk with the bios files on it. Problem #1. Files REFUSE to go onto floppy. (Gives me error "cannot copy an8_13: No ID address mark was found on the floppy disk.")
Ok so i said on to step two (try booting via comand prompt in safe mode). Followed the instructions in the txt file that came with the bios... Didnt work either.
By now im fuming. I thought ABIT boards were reliable? I have had nothing but problems with this board. Can someone PLEASE help me flash my bios?
The floppy is formatted right? I usually just make a boot floppy (create MS-DOS Startup disk option checked) when formatting. Then I download the zip file with the bios, flash utility, and directions. I unzip the files to the floppy I just made. I read the directions to figure out what I'm going to do when I reboot :). Then I reboot, booting from the floppy. I run the flash utility command pointing to the bios file I want to flash (with any switches needed) and then it flashes the bios. Remove the floppy and reboot and you're good.
Are you sure Abit doesn't have a Windows utility that does it for you? Most major mobo manufacturers have Windows flash programs now that download and flash the Bios for you.
Oh where would i find this? I didnt see one.
(when i click on the file, it AUTO extracts to wherever the file downloaded to, and it wont let me download the bios to the A:/ directly from the site so...)
formatted disk?? and if so cant u just extract to the desktop and then copy and paste onto the floppy?
Um? Dont fix what isnt broke? and dont most board come with falshing utitlies that do the hard work for you?
download the abit bios flashing program for windows all you do it click update and it finds the newest update and installs it no worries and even less work
should have come on ur driver/utility disk with your motherboard...look around on the cd and it should be there
Ahh ok, ill try it and let u know how it goes?
Ive used abits flash utility, its idiot proof....unless you press reset while its flashing.
