Flash (usb 2.0) drive speed?
Ashton
I'm looking for a USB drive for my laptop. I've seen people on one forum claiming that USB drives provide faster data access rates than class 6 SDHC cards - meaning 20mbps+
however when I look on ebay, they're trumpeting 9 and 10mbps!
What speed is normal for a larger-capacity USB 2.0 flash drive?
Real world, probably around 30 to 34 megabytes a second...give or take some.
I have a 8 gig thumbdrive I got from Microcenter for $25 and its good for about 30 to 31 megs a sec.
Sandisk Cruzer Micros do a pretty good job, I have 3. Good price too, look for a good sale, I picked up 4GBs last week for 22 each from Circuit City
My OCZ Rally2 has consistent ~32MB/s reads and ~20-22MB/s writes (with large-ish files; obviously read and write speeds tank with small ones). You just have to look for a decent drive.
sounds suspicious to me when all the 16 and 32gb drives had 9-11mbps write-speeds... sounds like they're hacked... (not that a high-r/w speed means it's not but this looks like another trick to pick out hacked ones)
and I need at least an 8gb, preferably 16 or 32 because this is going to be implanted and hard-wired into an eeepc as the main storage disk. I may look into that $25 8gb one above...
Whatever you do, avoid buying one from eBay unless you are 100% sure that you are buying from reputable dealer. There are tons of knockoffs on there with bullshit faked capacity and slow r/w speeds.
They especially love to make bootleg Sandisk Cruzer's.
I would be real hesitant to buy from eBay for one of these.
Flash drives are so cheap now...unless your looking for a 32GB its probable more cost effective to just go to office max and get it...plus you dont wait for it to show up in the mail.
If you discount the possibilty of getting scammed, it's dirt-cheep on ebay, but with the scammers do abundant now, I'm holding off most purchases unless I have a LOT of people say "oh I bought from him, he's legit"
I've decided to buy the $70 drive above, I need a large drive since this puppy only has 4gb avalible otherwise.
Be aware that large-capacity flash drives are inherently slower due to their use of MLC memory instead of the faster SLC that smaller drives use.
