BO(V)BZ said:If you have FLAC files, the easiest way to get them as lossless files on your iPod is to first transcode them to WMA Lossless and then use iTunes to import and transcode those to apple lossless. This keeps all the tags you had on the files, but of course would take a lot of time and HDD space if you planned to do it with many albums at once.
I've got a 4th gen 20GB.the Jones said:
The fourth generation click wheel, mini, U2, Photo, and Shuffle iPods are NOT currently supported.
Probably not. We're talking about lossless codecs remember? Unless the audio data gets mucked up during transcoding (which I don't think is likely to happen), the audio data will not be changed in any way.EnderW said:Will I degrade the quality of the files with all the converting?
That's probably what I'll do. Even after I get my new speakers in the car, I doubt I'll be able to tell a difference.Whitedude said:I just turn my FLAC's into 320 kbps MP3 files.
