Fixing Dead Pixels On Your PC Monitor Or Smartphone
Discussion in 'HardForum Tech News' started by Megalith, Jul 30, 2016.
  1. Megalith
    Megalith 24-bit/48kHz Staff Member
    13,004
    Aug 20, 2006
    Have any of you ever managed to actually revive or “unstick” a bad (dead/stuck) pixel? Both software (flashing the screen) and physical (applying pressure to the screen) “solutions” have never, ever worked for me, so I am really curious if this stuff is just wishful thinking.
    The window will start flashing multiple colors very quickly (epileptics take care). Leave it on for half an hour or so, and then check the pixel again. Try this a few times to see if it works. This is the common method when attempting to resuscitate a pixel, and that’s actually a very apt word, because it’s not unlike a defibrillation. You’re essentially trying to shock the pixel back to life, into a proper response that will have it acting as it should. And like defibrillation, it’s a desperate move that may or may not work. It’s more likely to work on a stuck pixel that shows signs of life than a dead pixel which may stay unresponsive.
  2. DeathFromBelow
    DeathFromBelow [H]ardness Supreme
    7,263
    Jul 15, 2005
    Neither method has ever worked for me. A dead pixel is a dead pixel.
    Thankfully the last time I had a dead pixel was on an iPhone 3G.
  3. Axehandler
    Axehandler Gawd
    635
    Dec 19, 2007
    I've had a dead pixel on my Monitor, and used this (as well as Pressure)
    Most of the time it's good but sometimes the pixel turns blue again thou :(
  4. rezerekted
    rezerekted 2[H]4U
    3,043
    Apr 6, 2015
    Tried both methods on a monitor years ago but it didn't work for me either. Current monitor (LG IPS) has no dead pixels.
  5. [21CW]killerofall
    [21CW]killerofall Aliens...
    3,091
    Mar 16, 2006
    These methods are only good to fix stuck pixels. If it is dead there is no way to fix it. My monitor has one pixel that has only the red subpixel working, the blue and green parts are dead.
  6. evilsofa
    evilsofa [H]ardForum Junkie
    10,078
    Jan 1, 2007
    I don't know if I've been lucky or just can't see them, but I've never seen a dead pixel.
  7. Koolthulu
    Koolthulu Gawd
    773
    Mar 24, 2011
    My monitor has a pixel that gets stuck every few months and applying a bit of pressure while flashing the screen will unstick it. Luckily I've never had the chance to try it on a dead pixel.
  8. azuza001
    azuza001 Gawd
    697
    Apr 4, 2012
    I have fixed stuck pixels that way, but it's only a temporary fix. Few weeks later back to being stuck.
  9. Budzman
    Budzman [H]ard|Gawd
    1,034
    Jul 9, 2001
    Never ever has anything worked to fix a dead pixel.
    Nytegard likes this.
  10. THRESHIN
    THRESHIN 2[H]4U
    2,970
    Sep 29, 2002
    i have a dead pixel on my monitor....i'm still rocking a 24" samsung 245BW. it's been probably over 8 years now. the dead pixel was there from the beginning, near the lower right corner and it's just stuck on blue. i never notice it thanks to the colour and location. i did try these methods long ago to revive it but nothing worked. i stopped caring.
  11. Greyryder
    Greyryder Limp Gawd
    453
    Apr 18, 2001
    Fixed a couple of stuck pixels, on an old NEC monitor, years ago. The massaging technique just damaged the surface. But the flashing color thing worked, took it several days, though. They stayed fixed, up until the monitor refused to power on, one day, after yet another power outage. As I recall, I wound up having to fix another stuck pixel, on the Acer that replaced it, and it's still fine.
  12. Wizzard
    Wizzard Limp Gawd
    269
    Sep 8, 2012
    I've fixed dead pixel on laptop displays with massage - IMHO I believe it was because laptop displays are much thinner than desktop displays, and of course phones have protective glass over the front.
    It's far from 100% effective, but I'll always give it a shot.
  13. pothb
    pothb [H]ardness Supreme
    4,997
    Mar 24, 2007
    stuck != dead.
  14. danmoody
    danmoody Limp Gawd
    330
    Sep 21, 2004
    lol I had my dogs knock a monitor off. I had a group of about 5 green pixels. I rubbed em out with an eraser and they never had any issues again. I bought the monitor in 08 had the pixel issue in 10. I sold the monitor and it is still in use till today. It's worked great for me. :)
  15. Nytegard
    Nytegard 2[H]4U
    3,126
    Jan 8, 2004
    And this is where the difference becomes annoying when trying to discuss it. Most people seem to act as if they're the same, but you can't revive a dead pixel. Sadly, they're far more common than they're made out to be, and the best way to avoid them is not to look in the first place. Even manufacturers with a zero bright dot policy still don't have a zero dead pixel policy. You have to be a super annoying customer if you want a working monitor.
  16. schoenda
    schoenda Gawd
    860
    Apr 8, 2003
    one dead pixel - above program didn't work...I did however have a seizure. (No not really, but pixel still dead)
  17. steakman1971
    steakman1971 2[H]4U
    2,433
    Nov 22, 2005
    I bought a used ThinkPad from Ebay about 10 years ago that had a dead pixel. No amount of rubbing fixed it. I only paid like $100, and the pixel wasn't in a spot that bothered me (too much), so wasn't the end of the world for me.
  18. Quartz-1
    Quartz-1 [H]ardness Supreme
    4,257
    May 20, 2011
    You forgot the percussive maintenance option when the 'dead pixel' is actually an insect and giving the monitor a sharp hit will knock the thing loose.
  19. Gman1979
    Gman1979 Gawd
    637
    Sep 21, 2011
    Never had luck with doing this to monitor sized screens, but I did have a dead pixel on an iphone 3GS "fixed" by a friend of mine using the piezoelectric mechanism from a lighter.
  20. Tak Ne
    Tak Ne [H]ard|Gawd
    1,233
    Jan 28, 2008
    Tried this and it worked great on my Sony BVM-20F1. ;):);):sneaky::);):)
  21. krotch
    krotch [H]ardness Supreme
    4,509
    Aug 12, 2004
    I've had luck with the flashing thing to fix a stuck pixel. Sadly there was like 15 of them spread out through the monitor, which it only fixed one. Not the others. I didn't care all that much, as it was a crappy screen to begin with and long since replaced it. It's just the monitor for my file server, which I rarely have a need to look at it.
  22. Jovian
    Jovian Limp Gawd
    362
    Jun 8, 2004
    Absolutely have fixed a pixel with pressure of a finger. It doesn't need much so dont go too hard.
    When LCD monitors were first coming out mine had three dead pixels which at the time was within "acceptable" range for new monitors. Applying slight pressure and rubbing revived the pixels and the monitor is still used today without any issues.
    That said I have not had to do it on current tech
  23. LurkerLito
    LurkerLito 2[H]4U
    2,133
    Dec 5, 2007
    Stuck pixel yes I corrected one with a color flashing program once, but dead pixel was a no go.
  24. ianken
    ianken [H]ard|Gawd
    1,953
    Feb 21, 2006
    My 4K Dell has a dark pixel. In Dell bullshit warranty land dark is not dead. Only bright is dead.
    I have a 4K HP at work. Flawless.
