Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
you wouldn't with out an extra controller card.....and not sure you would then.....why two burners? TheDVD does both......... ...and both burners will function as a cd?????
Yeah you are going to need an IDE controller card, and more than likely RAID cards are going to be the cheapest if you actually want to use that setup.
That is one of the limitation of the current IDE PATA standards, One master and one slave per controller.
