What if I were to get 2 GTX's in the future...Is it possible to have 2 rad's..say from one GTX to the other, to 1st rad, to CPU, to 2nd rad, to res, then to pump? Wouldnt that cool the water as it went from both GTX's (hot) to the CPU to keep the CPU temps down so it doesnt get the heat from the 2 gfx cards? If possible, I wouldnt start initially. Id get my stacker first, then this. Also, the swiftech radiator does fit in the 5 1/4 bays in the stacker... Theres a video of its installation. But which way would you have the fans blowing? into the case or out the front? blowing or sucking?
other than having the res before the pump inlet, component order does not matter. water temps throughout the loop are so close to being the same that the difference it not usually even measurable.
