First WC build questions.
Solhokuten
Looking to WC the system in sig. I will be getting a Titan XP to replace the 980s.
I have ordered the following from ekwb.com. What else do I need?
Also thinking about getting a a new case with a side window. Which one would you guys recommend? Thinking about the Corsair 780T.
EK-CoolStream XE 360 (Triple)
3831109860427$ 99.99Ordered: 1
$ 99.99
EK-Vardar F4-120ER (2200rpm)
3831109867617$ 19.99Ordered: 3
$ 59.97
EK-FC Titan X Pascal
3831109831663$ 123.99Ordered: 1
$ 123.99
EK-FC Titan X Pascal Backplate - Black
3831109831700$ 34.99Ordered: 1
$ 34.99
TUBE PrimoChill PrimoFlex™ Advanced LRT™ 12,7 / 9,5mm - Bloodshed Red RETAIL 3m
3831109850534$ 24.39Ordered: 1
$ 24.39
EK-ACF Fitting 10/13mm - Black
3831109846421$ 6.49Ordered: 8
$ 51.92
EK-Ekoolant EVO Blood RED (concentrate 100mL)
3830046999535$ 9.99Ordered: 1
$ 9.99
EK-XRES 140 Revo D5 PWM (incl. pump)
3831109843079$ 153.99Ordered: 1
$ 153.99
EK-Supremacy EVO X99 - Nickel
3831109800362$ 67.99Ordered: 1
$ 67.99
Lets see. You have at least one radiator. you have one block for CPU and one for GPU. You have a reservoir and pump combo, and you have the tubing and fittings to tie them all together.
So you have all you absolutely need to get started, I think.
You might want to get one or two extra fittings just in case you want to attach temporary fill or drain lines.
A handful of 45 degree bends probably wouldn't hurt. They can be pretty useful when routing tubing.
You might also want a couple of ports, one for draining and one for bleeding.
Otherwise, looks good.
May be a little bit on the low side on radiator capacity for extreme overclocking, but it should make for a decent loop.
Thanks for the reply! I'll grab an extra 240 rad and those ports, 45 degree fittings like you recommend.
What case do you think i should get for all of this?
