So as the title says, I am making my first WC loop. I have all my parts picked out and know what I want to do, I just need the reassurance it will all work together alright.
Here is my order at frozencpu:
This will be cooling an i5 2500k inside a Coolermaster 600T, single loop CPU only.
My concerns:
Are the barbs going to be okay and compatible with the hose/all necessary fittings?
Should I go compression fittings instead of barbs?
Will the pump/res combo be enough to cool this single loop?
Is there anything else I will be needing?? Possibly a T fitting for draining or any other necessity I may have overlooked
As always thank you all for your help!!
XSPC EX240 Dual 120mm Low Profile Split Fin Radiator
G 1/4" Fittings (Qty. 2): 1/2" ID Barb
EK Supreme HF Universal CPU Liquid Cooling Block w/ LGA 2011 Hardware - Rev 3 - Acetal (Sockets 775 / 1156 / 1366 / 2011 / 939 / 940 / 754 / AM2 / AM2+ / AM3)
XSPC Dual 5.25" Bay Reservoir - Laing D5 / MCP655 w/ Blue LED Light
PrimoChill PrimoFlex PRO LRT Tubing 7/16"ID 5/8" OD with 3/32" Wall - White
5 Feet
IandH Dead-Water Copper Sulfate Biocidal PC Coolant Additive
Distilled Water from a local drugstore/Walmart
My concerns:
