Tigershard
- Mar 9, 2011
This weekend I installed my first water cooling system. I did it the hard way, having a system I had already been using for a bit and adding water cooling to it. I purchased a XSPC Rasa 750 RX360 and the XSPC Watercooling block for my video card. My CPU is an intel i5-2500K and I'm still using my trusty Geforce GTX 480. I had an awesome case, the SuperMicro SC747, but I couldn't fit the XSPC watercooling kit in there, so I purchased a Coolermaster HF932 instead.
I don't remember how long the install took me. I cleaned the radiator out with boiling distilled water many times, and washed the CPU and GPU blocks with vinegar. Either way, by the time I was done I was tired and cranky, but the results made all the work worth it.
Before watercooling, my i5-2500K was idling at 29C with the stock cooler. Running BF3, I believe I got the CPU up to 50C+. My Geforce 480 was idling at 51C, and would reach temps of up to 91C when running Furmark.
Now that I have everything setup, when I looked at my temps idle I was already super impressed. My CPU was idling at 21C and my GPU at 30C, and this was with the radiator fans running at 50% to keep the noise down. Loaded up Furmark and later BF3, and my GPU never got above 51C, and the CPU never went above 40C. When I turned the fans all the way up, both CPU and GPU dropped by 2-4C.
I haven't done any burn-in or stress tests yet (other than Furmark), but I plan to before I start overclocking. I can't believe how horrible the stock Geforce 480 cooler was. A 40C difference in Furmark? Scary. I'm wondering if I should overlock the GPU as well as the CPU.
