First time shopper of LCDs
Well as i said above, this is ganna be my first lcd im going to buy, so I decided to look at some 17" LCD panels. I am a heavy gamer but i hear 16ms is fine for gaming and i have a friend who has a 16ms refresh rate and his runs beautifully. Now my question is this: Is this a good monitor here? : http://www.newegg.com/app/viewproductdesc.asp?description=24-180-018&DEPA=0 . Its a Aduevu 17" LCD screen with 16ms refresh rate and other goodies that u can see at the link. Is it any good? It got great reviews. I really dont have too much money to spend, about 350 max. Lemme know guys thanks
Since I know nothing about either unit it's hard to give an opinion. I can tell you I bought several Envision monitiors back before anyone heard of them and I still give them my highest recomendations.
I has been posted too many times specs don't really mean squat because there are no standards anyone has to follow to make the specs meaningful.
I'd pick one and give it a shot. With the Egg if your not happy you can return it. In the end it's what YOU think that matters right? ;)
Luck
Keep in mind that Newegg has a dead pixel policy of 8 or more on LCDs. I would go with someone like MonitorsDirect.com or Dell. Those companies let you return it for basically any reason, free of charge.
True enough, but on his budget I kind of ruled those two companies out. The Egg will let you return a product for other reasons, doesn't have to be dead pixels ;)
For what reasons WILL the egg let me return for?
Ok, heres the bottom line, those 2 monitors i posted i was just wondering if its a good idea to try those out. I dont know the policy of newegg with their lcd monitors even tho i searched :\ but the thing i need to know is if u were in my situation woiuld u try those monitors or not, or would u go someplace else to buy a monitor?
Hey guys i found this monitor that would fit my description quite nicely: http://www.newegg.com/app/ViewProductDesc.asp?description=24-014-053&depa=0
Its got pretty good specs and nice reviews. What do you guys think? Also, have any of u dealt with monitorsdirect.com ? I like their return policy so i was thinking of buying from there, i just have never bought from them so i dont know how safe/reliable they are. Input?
http://shop.monitorsdirect.com/product.asp?sku=2528978 Also found this Samsung 12ms response time 17" flatpanel, almost too good of a deal to be true. Is this monitor for real?
WOW you guys are completely stupid, I have been posting for days and i hardly get responses. WHATS WRONG WITH YOU PEOPLE? PLEASE HELP ME
Thanks jacko but i already tried it :| and i found stuff on 710 but not on the "N" version of it. And the only reason i got mad now is cuz i posted like 5 times over 3 days and not a single person even tried to reply. :confused:
If I'm not mistaken the only difference between the 710T and 710N is that the 'N' has no DVI input, meaning is analog only. That's a big deal to some people and not so big a deal to others.
Well its a big deal to me cuz of the 100 dollar price difference :p but what do u think of the 710N? U think its a good deal? Im thinking of grabbing it from dell.com
I honestly don't know because I've never used one. I know Samsung panels are generally well regarded but I don't think I could buy an LCD without a DVI input for myself.
Well im kind of confused then, some people say the difference between analog/DVI is barely noticable and some people say its a huge difference and cant live without it. Which one is it!
Ignorance is bliss. If you've never seen DVI then you won't be able to tell the difference right? Or you could take the red pill and then voila, welcome to the matrix.
In all seriousness though, most reviews I've seen say that there really isn't that much of a difference and that's what manufacturers have been saying as well. However, many people do swear by it. So I guess just save yourself $100 or go check out the difference at your local computer shop.
Yea, only problem is that the local shops around here kinda suck, they got low quality establishments (computer wise, the store itself is nice and flashy, but they have no comp knowledge at all) so half of them dont even know wheter the stuff is hooked up to DVI or not and they prolly know less about LCDs than i do. They hire high school kids who could care less about what they sell
Ha! Good Luck with that. I don't have an answer for you, other than read reviews on different sites and post your question on a bunch of messege boards. As far as flat panel displays go, I'm sure there aren't a whole lot of gurus in the field.
But anyways..........
Here's a Link you might find helpful
Monitor Goodies
i just got a my 710t in today and I switched to using DVI. Compared to the regular VGA, there really isn't too much difference as far as the sharpness. Both pictures (I have two lcd's set up right next to each other, one on DVI the other on VGA) are clear and pretty much fall into the same pixels. The auto VGA function seems to work very well. But I can notice this big difference. When you are not using the native resolution of the LCD the DVI looks MUCH better. The text is much more legible (like the bios settings area) and because it is DVI everything is perfectly centered and aligned. With the VGA if you use anything besides the native resolution, the automatic centering/alignment function never works well.
The other major difference is that with the DVI, there are no "waves" or jitters in the picture. Everything is perfecty still. I never noticed how jittery VGA was untill I look at DVI lcd. With my VGA, when you set the refresh rate too high, the picture became jittery and fuzzy, but with DVI it doesn't matter; the picture is perfectly clear at any setting.
Would someone who is coming from a CRT notice the differences in DVI and analog if ive never seen a DVI input before? I just hope i dont notice a difference becasue i have never seen DVI
i recently just came from a CRT too. any lcd kicks the ass of a CRT when it comes to clarity. When I look at any CRT now i feel like it is so blurry that i will get a headache from looking at it for more than a few minuets.
The only thing that CRT's do better is refresh rate and resolution. A crt generally looks good at any resolution because their electron gun can fire any resolution. With a LCD you are stuck to the native resolution or else you get horrible interpolation. (not so bad on DVI though).
LCD's also "ghost" or they blur because the lcd cannot change fast enough for fast action video games. On my 12ms LCD the ghosting is very minimal and it doesn't bother me at all.
You would never tell the difference between a DVI and VGA lcd screen unless you have them set up right next to each other like i do. Even then it's only a little difference.
But going from a CRT to LCD is a huge improvement.
Hehe, well i picked up the Samsung 710N which is analong/12ms so hopefully it will do my games some justice, not to mention my eyes :p
