First Time OC'er...Help!
Hey Everyone!
I'm brand new to OCing, I love this website and the website always has great advice and reviews for upgrades etc.
Thermaltake Armor LCS Liquid Cooling System
Asus P5N32-E SLI Motherboard BIOS 1201
X6800 Intel Core 2 Duo CPU
2GB Team Xtreme PC-6400 800mhz RAM
BFG 8800 GTX Ultra OC Video Card
Soundblaster X-FI Xtreme Music PCI Soundcard
Ageia PhysX 128MB PCI card
Windows Vista Ultimate x86 with all updates
I would like some help achieving a STABLE overclock with this system. I've messed around a little bit, (YES, I ALREADY READ THE GUIDE) and I don't get anywhere.
Windows locks up, and Oblivion frequently crashes, but not when I'm running stock.
Annoying.:mad:
I'm looking to overclock my system, MANUALLY, not using the Asus OC crap, included in th Bios settings.
If someone could provide a step by step guide with numbers and figures, bios settings etc,
besides "up/down the multipiler" etc.....I would really appreciate it, because I should be able to achieve better performance with this system.
Cheers!
If you're crashing really fast, that probably means you haven't engaged your PCI/PCIe lock. But they're usually enabled by default...
Try voltages next. Or doing light overclocks, before moving into uncharted territory.
