blendingnoise
- Jan 3, 2006
I wanted to thank all the people who post in this forum and in my threads because you all are a huge resource whenever I am trying to figure out my computer. I used an athalon 1Ghz for a really long time and never got into overclocking because a lot of my parts were generic and not the best. My motherboard and video card died so I finally had an excuse to just buy a whole new system and am loving it. Didn't realize the difference between what I had and what I have now was this much. I was happy with stock but everybody online mentioned how easy it can be if you or not pushing limits and the c2d's have a fair amount of capability. So simply for the hell of doing it I read up and tried it.
I have an e6300 running at 400x7 right now, gskill ddr2 800 ram running w/ 2x multiplier, evga 7900gs ko set at 615/1590.
I need to improve my temps as I am running 52 idle right now with the stock intel hs, with 66 at the highest when loaded under TAT or orthos. I would guess that it has to do with not having experience with applying thermal paste. I am ordering a new heatsink when I save some money up again. Computer hit the wallet hard.
My graphics card runs at 44 idle and ramps up to 60 at the highest. Hovers around 56 avg when running 3dmark, playing games, rthdribl.
I have not adjusted any voltages except I put my ram at +0.1v. Cpu fan is on auto.
For some numbers. My pcmark05 score went from 5370 to 6820. My 3dmark06 score went from 4451 base with no OC, to 5216 with a GPU OC, to 5513 after all was said and done.
Memtest ran 6 passes fine, ran 3dmark and pcmark a couple of times along with rthdribl. Ran orthos for almost 2hrs and everything was fine. Didn't want to leave it any longer at those temps. Once I order a new HS I will run the tests overnight.
My main questions were, could I run it daily at those temps for a couple of weeks till I order a HS? Are the benchmark numbers sounding about right? If my ram is rated from 1.8v to 2.0v what should I run it at if all the settings work?
