leSLIe
- Oct 18, 2004
get a Quad Core, ditch that PSU and get a Corsair one
Hey guys, thanks for all your input thus far. I've revised my build and saved it as a shared newegg wish list titled both, 'LongWayRound New Comp' or 'New Gamer Build'. Problem is, I can't search for those 2 lists I just saved... typing all this on a laptop b/c my old desktop is fried right now...
Which monitor are you considering buying? When exactly are you planning to buy this monitor?
You have changed my thinking here... I think I'm going to save a bit of $$ on the hardware and get a new monitor. So that I can fully utilize these beastly GPU's. Any suggestions? I'll have to read up on these. Likely a 24" Wide Screen.
I'm going to get a new monitor now.
Which monitor/resolution are you currently using?
From the looks of the site, J&R is nothing more than a "high-end" Circuit City/Best Buy clone. I suggest getting the peripherals (keyboard, mouse, speakers) and any additional software (read: games) you want with the gift card. (For the case, power supply, and the internal components, NewEgg beats J&R every inch along a country mile.)
But again:
- Get the E8400 and P5Q Pro bundle at NewEgg. The E8400 can overclock just as easily as the E8500/E8600.
- For overclocking, the AC Freezer 7 Pro won't cut it. Get either the OCZ Vendetta 2 or the Xigmatek HDT-S1283 (with retention bracket).
- If you're overclocking, get the DDR2 1000 kit. Chances are that, if this rig is to be used more for gaming than anything else, you won't need the second 4GB RAM kit.
- Two WD6400AAKS hard drives are faster and have more space than one 1TB Caviar HDD for around the same price. Consider those instead.
- VisionTek has a limited lifetime warranty; Sapphire has questionable reliability.
- The Antec 850W power supply is expensive overkill. The Corsair TX750 is a comparative bargain (though still overkill).
If you like modular cabling, consider the Corsair HX620. But keep in mind that the TX750 costs less but has more power (not that you really need the power; the point is that it costs less than the HX620).
... those heatsinks look intense, is either of them easier for a novice to work with? price is no option for this component.
I don't want to raid my HD's, doesn't that shorten their lives? I want the hard drives to last awhile for sure.
Listen to tiraides and HG... they're starting to repeat themselves here.![]()
