- Oct 29, 2000
Hey all,
After waiting forever for Corsair to launch their HG10 N980 brackets, and then starting to think about customizing a couple of Swiftech H240-X kits, I finally came to the conclusion that I might as well just build a custom water loop.
I've always wanted to do this, but never gotten around to it, so why not start now?
I've been doing a lot of reading, and come up with the tentative build plan below. I would really appreciate any comments or feedback, especially from the perspective of me being a custom WC loop n00b.
Loop configuration
3x 140mm radiator up top in my Corsair 750D in push-pull blowing out.
2x 140mm monsta radiator up front in my 750D blowing out.
Pump/reservoir combo in drive bays.
I'm thinking of going with the following layout for the sake of simplicity:
Pump -> 2x 140mm Monsta -> GPU2 -> GPU1 -> CPU -> 3x 140mm -> reservoir -> pump
I had originally considered putting a radiator in between the GPU's and CPU, but everything I've read suggests that component ordering isn't a big deal, as the coolant moves fast enough and reaches an equilibrium where it isn't significantly warmer after a hot component, or significantly cooler after a radiator, so I decided that for layout simplicity's sake. Any feedback here would be appreciated.
Why I selected the components I selected:
CPU Block:
WC reviews are rather limited, but the EK Supremacy EVO seems to be performing the best in every test I have seen. Based on the fact that my chosen radiators are copper, I decided to go with the copper version rather than the nickel. I know Copper-Nickel doesn't have much in the way of galvanic corrosion, but better safe than sorry, right?
GPU Blocks:
I like the ability to reuse the water block Alphacool allows, so I don't have to break into the loop if I am upgrading GPU's and can save some money by just getting the full cover plate.
Radiator 1:
I have seen several reports of people fitting these up top in my Corsair 750D case, even though Corsair lists the max radiator size as 360 or 280mm. 30mm is the thinnest I can find, as I want to do push-pull, and I am hoping to avoid motherboard interference. I will need to do some closer measurements to make sure it will work. The GTX 110i I currently have is 26mm thick, and it is very close. Need to make sure I can squeeze in 4 more mm.
Radiator 2:
Wasn't originally going to go with the 86mm Monsta up front in the 750D, but it isn't THAT much more money than the more normal sized 280mm rads, and if I have the space, why not?
Reservoir/Pump:
Ive heard good things about Swiftechs pumps, and I like the drive bay reservoir design. I liked the original Maelstrom better because it had the coolant temp readout on it, but they ave been out of stock for a year now I think, so I don't have high hopes of finding one.
Push Fans
I selected Swiftech's helix fans as they receive positive comments on pushing a lot of air, and doing so quietly. I'm not entirely sold here, but they are my choice for now.
Pull Fans:
This one was easy. I have these already, and they look so pretty in my case
Fittings:
I didn't like the concept of barb fittings and zip ties, especially if I have to cut them off. Compression fittings seem like a more engineered solution and less like a hack. I'm not entirely sold that the fittings I have selected are the best, and would love some opinions. This being my first build, I am rather surprised at how much they cost. Usually hardware like this is dirt cheap. I get the impression this is the equivalent of expensive cables, for WC. I would appreciate any suggestions for cheaper compression fittings (but not so cheap they will let go and soak my rig
Tubing:
I'm not that well informed on tubing. I selected this semi randomly Would appreciate any thoughts regarding alternatives.
Some questions:
Much appreciated guys!
- CPU Block: EKWB Evo Supremacy Full Copper
- 2x GPU Blocks: Alphacool NexXxoS GPX - Nvidia Geforce GTX TITAN X / GTX 980 Ti M01
- Radiator 1: Alphacool NexXxoS ST30 Full Copper 420mm
- Radiator 2: Alphacool NexXxoS Monsta 280
- Reservoir/Pump: Swiftech Maelstrom V2 Dual Bay Reservoir w. MCP50X Pump
- 5x Push Fans: Swiftech Helix140-PWM
- 5x Pull Fans: Corsair SP140 fans.
- 12x Fittings: Swiftech Lok-Seal 1/2" Compression fittings
- Tubing: Swiftech Truflex 3/4OD, 1/2ID tubing
- Coolant: Simple distilled water + PT Nuke
Loop configuration
CPU Block:
GPU Blocks:
Radiator 1:
Radiator 2:
Reservoir/Pump:
Push Fans
Pull Fans:
Fittings:
Tubing:
Some questions:
- I see a lot of people using elbow type fittings between GPU's in SLI instead of just a short length of tubing. Is this a good idea from a performance / functionality perspective, or just for appearance? (those elbow fittings are surprisingly expensive, and I won't spend THAT much time looking at them)
- I'm considering two quick disconnects around GPU 2, so if I move to a single GPU in the future, I can easily cut the second one out of the loop. Good idea? I'm not 100% sure though, as they seem really surprisingly expensive.
- If I am using distilled water and PT nuke, should I also use a silver kill coil? Or maybe drop the PT Nuke and add a coil? Thoughts?
- Anything else I've missed, or beginner mistakes I have made? Are there things I am doing that needlessly add cost?
