Hello everyone I’m new to this forum, and this is my first time building a computer. Before I just buy a custom built from someone. I was referred here for advice and help since most of you are knowledgeable about computers. I'm not up-to-date with the new computer technologies, so I don't want to buy parts that aren't compatible. I want a really good built that has a lot of upgrade ability in the future.
Primarily for gaming; games like BFBC 2, SC2, CIV 5, CSS, TF2, and future games.
Some photoshop and graphics, Web browsing, and just general stuffs like Microsoft Office suit and webcaming. My current computer (specs below) can do everything, except for gaming. I can only play CSS and TF2 at medium settings.
Im hoping to spend around $1000 after tax & shipping, excluding rebates, but willing to spend a little more if it’s a good built. Maybe + 150 to 200
3) Where do you live?
SF, CA
CPU: I want Quad core, preferably Intel. I dont like AMD. Can someone explain to me the difference besides the prices? I’m assuming the Bloomfield is faster than the Lynnfield? Whats LGA? And high W on the cpu requires higher vottage PSU?
Motherboard: List the motherboard that will be compatible to the cpu you choose
CD/DVD/BluRay Drives: Sony?
Memory: 8gb. Im assuming its ddr3? Corsair or Ocz
HD: Probably go with a 1TB. Should I partition it, or get a 2nd hd? SATA is the common ones now right?
Videocard: ATI or NVidia? Which one is better for gaming, or is it base on preference? Im assuming PCI-express x16. I don't know what’s the fast speed for video card now
Soundcard: something decent that's cheap
Ethernet card for internet: fastest speed.
Powersupply: OCZ, Cooler Master, or Corsair? Gaming system needs a high powered psu right? So at least 600 to 700W?
Case: Which of these two should I get
(1) http://www.newegg.com/Product/Product.aspx?Item=N82E16811119138
(2) http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
Operating system: Windows 7 or stick with XP Pro?
Do I need any extra cooling devices like fans or the cases Im targeting has enough fans?
Logitech laser mouse
Logitech Wired keyboard
Logitech 2.1 speakers
Sennheiser headphones
Monitor: SAMSUNG 941BW Black 19" 4ms (GTG) Widescreen LCD Monitor 300 cd/m2 500:1
Cat 6 wired cable for internet
6) Will you be overclocking? No
I want to start buying end of January 2011, and will build after I get all the parts.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Crossfire has something to do with using 2 vid card right? Do you need 2 monitors?Don’t know what RAID or firewired is. I guess usb 3.0 or 2.0 and SATA. I’m not too knowledgeable about motherboard
See #4. I don’t have another cd key so planning to get a legit version of Microsoft. Windows 7 or stick with XP Pro?
My current computer specs. It is very ancient. I have been using this computer for 7 years.
CPU: Pentium 4 3.0Ghz HT 800FSB
Motherboard: Intel D865PERL (Desktop/Motherboard on Intel Website under download)
BIOS: 02-13-05 22:02:08 ver. 08.00.10
CD/DVD Drives: 8x DVD
Memory RAMs: OCZ 400512ph 4x 512mb latency 2.5-3-3-7 premier series pci 3200 dual channel DDR (added more RAMS)
Video Card: ATi Radeon X1950 Pro AGP 575MHz 8X/4X 512mb 256bit 8-channel GDDR3- 1.38 GHz Shader Model 3.0 (Upgraded)
Power supply: OCZ Fatal1ty OCZ550FTY 550W ATX12V v2.2 / EPS12V SLI Ready 80 PLUS Certified Modular Active PFC Power Supply (Upgraded)
Hard drive: 120gb IDE ATA100
Sound Card: Creative Sound Blaster SB0570 Audigy SE 7.1 Channels PCI 24bit 96KHz SNR: 100dB (Upgraded)
Logitech speakers and Sennheiser head phones
Logitech laser mouse and wired keyboard
Thanks for the help.
SF, CA
