Maverick1337
- Feb 27, 2011
Hello HardForum!
This is my first post and I hope I'm doing everything correctly. I've been directed to this page in hopes to get help with building my new custom gaming PC. I've researched a lot on all the parts and have come up with a list of everything I will need. Some things to point out are I would not like to spend more than what I have listed ($1500) but I would be even happier to spend less (~$1000). I want this machine to handle games really well. World of Warcraft, BC2, Crysis and really anything that can be thrown at it in the near future. Also another note is I probably won't build this baby until my next month's paycheck so hopefully the parts become cheaper. Anyways, here's my list and hopefully you guys can help. Thank you in advance for any advice/help; it is definitely appreciated!
Heavy PC Gaming, Some Photoshop, I am a Civil Engineer and will work with CAD, I want to be able to run many things at the same time.
My budget is around $1500 but if I can get what I need for cheaper than that is an obvious plus
3) Where do you live?
San Luis Obispo, CA
Motherboard, Processor, RAM, Hard Drive, CD-ROM Drive, Graphics Card, Heat Sync, Case, Monitor, Power Supply.
None. Starting from scratch.
6) Will you be overclocking?
Yes, both the processor and video card.
~23"
I can start buying the computer within the next month once I get my next paycheck.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
The motherboard is going to be the renewed Sandy Bridge LGA 1155, it goes hand-in-hand with the 2500k processor.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Windows 7 64-bit free through school.
Mother Board
-Sandy Bridge Socket H2 LGA 1155 ~ $200
(Not available)
Processor
-Intel Core i5-2500k, 3.3GHz (I will Overclock it) ~ $216.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072&Tpk=2500k
Video Card
-EVGA NVIDIA GTX 570 (Fermi) (I will Overclock it) - $349.99
http://www.newegg.com/Product/Produ...593&cm_re=evga_gtx_570-_-14-130-593-_-Product
RAM
-G Skill 1600 8GB (2x4GB) ~ $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428&cm_re=g_skill-_-20-231-428-_-Product
Hard Drive
-Seagate Barracuda 1TB 7200RPM SATA ~ $64.99
http://www.newegg.com/Product/Produ...&cm_re=sata_hard_drive-_-22-148-433-_-Product
Power Supply
-Antec True Power New 650W ~ $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371021&Tpk=antec true power new 650
Heat Sync
-Cooler Master Hyper 212 Plus ~ $29.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&Tpk=cooler master hyper 212 plus
Disk Drive
-Samsung BD/DVD/CD-ROM, DVD/CD-RW ~ $69.99
http://www.newegg.com/Product/Produ...=internal_cd_rom_drive-_-27-151-222-_-Product
Case
-NZXT Black Computer Case, Blue LED Side Fan ~ $69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146025
Monitor
-ASUS 23" LED-Backlit Full-HD ~ $189.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236117
_________
Total: $1,370.92 (without tax)
Total: $1,484.03 (with tax)
*Unsure about: CD Drive Drive, Case, Graphics Card
San Luis Obispo, CA
~23"
Mother Board
(Not available)
Processor
Video Card
RAM
Hard Drive
Power Supply
Heat Sync
Disk Drive
Case
Monitor
_________
