DarrisBard
- Oct 1, 2009
Hi HardOCP forum.
My immediate Goal is to play Fallout 3, Prince of Persia 2008, and PES 2010 at 1280 x 1024.
My current pc is getting very long in the tooth (Crt, ddr 400, x700 etc.) even though I tend to stay behind the curve. I'm trying to build a decent machine but I have noob questions.
I'm not really looking for a parts critique but I'll list them so we are on the same page and then I'll ask my noob questions.
Motherboard: Intel dg41ty mATX
CPU: E7500 FSB=1066
Ram: 2x2 gb dual channel corsair ddr2-800
GPU: Sapphire 4670 512 mb
HDD: WD 320 GB 7,200 rpm
DVD: Samsung burner
Speakers: Logitech s220
Case: Cooler Master elite 341 mATX
PSU: CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Certified
Monitor: 19" LCD Hanns-G
OS: Windows 7 home (oem)
Ok here are my noob questions. This forum looks like a very knowledgeable/helpful place so thanks in advance.
1. Does the Motherboard autodetect the FSB as 1066 (matching the cpu)? Or do I have to muck around in BIOS? I don't intend to overclock but I read that there aren't really options for overclocking on this motherboard. I was worried that if it sets it to 800 I wouldn't be able to change it.
2. What's up with ram speed? I've read things about matching FSB speed and ram speed...but for example some motherboards only support ram that is faster than the FSB speeds. Is it pointless for me to get ddr2-800 and I should stick to ddr2-667?
3. Also on ram, what's that about 32-bit OS' not detecting all 4gb? Still a problem with windows 7?
4. The 4670 GPU isn't limited by the PCI-e 16x 1.0 bandwidth is it? Is 2.0 that important?
5. Any thoughts on Intel HD audio? I do listen to cd's on the computer often. I wonder if a pci sound card will help in that department or if just having those speakers is enough?
6. That CM elite 341 case has 4 fan spots (for 120 cm fans I think). 1 in front, 2 side, and 1 rear. Front and sides intake, and rear exhaust, right? Or do I not need side fans at all? Are they pointing the right way?
I really appreciate any help. I feel pretty confident about putting it all together because I took apart an older machine and reassembled it correctly. Obviously you make mistakes when you do stuff the first time. This comes to about 800 bucks (I'm in the US) and seems like it should do what I want. Got to wait for windows 7 to come out but I figured I'd ask now.
DB
CPU: E7500 FSB=1066
DVD: Samsung burner
DB
