First Time Build - Gaming PC - Need Advice
HBW
Hey just getting ready to put a build together for gaming/general use and this is what I have so far:
Processor: Intel E8500
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
Video Card: Saphire 4870 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102795
Mobo: GIGABYTE GA-EP45-DS3R Intel P45
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128344
RAM : G.SKILL 4GB (2 x 2GB)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231145
PSU: CORSAIR 750TX 750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
HDD: WD WD6400AAKS 640GB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
Pioneer 20X DVD±R DVD Burner SATA
Case: LIAN LI Lancool PC-K7B Aluminum/ SECC ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112154
HSF: XIGMATEK HDT-S1283 120mm Rifle CPU Cooler and Retention Bracket
I'll be running Vista Home 64 which I have already and running a 24" monitor at 1900 x 1200. Trying to keep this around $1000 and my newegg prices show these
at $1040 before any of the rebates. Not sure on the Mobo and to go for the GTX 260 or keep the 4870. Any help is appreciated!
Parts choices looks good to me.
As for which video card to go with, it's a tossup actually between the HD4870 1GB and the GTX 260 with 216SP. Performance is the same between the two cards in most games. The other factors you now have to look at is price, warranty and quality of customer support.
The motherboard is fine. However, since it supports CrossFire, which only works with AMD/ATI video cards, you may want to consider leaning towards the HD4870.
Having said that, I suggest looking for another brand. Sapphire has been hit-or-miss lately with the quality of its parts.
Everything looks good. At 24" and 1900 x 1200, the 1GB 4870 is great. Keep it.
Looks like a decent list HBW, we could split hairs on cpu and psu but overall you're doing fine. Here's the thing you could get a GTX260 especially if you're waiting on the 216's. The 4870 vs 260 difference is minimal.
Keep mentioning it, but it's hard for me to support the video card @ $270AR when the 512 version is only 199.99AR = 35% premium.
