Hello all, it's my first time building a complete PC all at once (Have been for years just upgrading piece by piece). I was hoping that if anyone could put any input in, I would really appreciate it. I can't afford to be making mistakes, and I know that HardForum is full of experienced people.
1) What will you be doing with this PC?
Primarily gaming. First games to be played on it will be Heart of the Swarm, and League of Legends.
2) What's your budget?
Looking to keep it under $900 after taxes.
3) Which country do you live in?
Currently Residing in Windsor, ON, Canada.
4) What exact parts do you need for that budget?
All the parts are listed below, with what I currently am considering.
5) If reusing any parts, what parts will you be reusing?
No, currently have no parts to salvage.
6) Will you be overclocking?
No.
1080p 23".
This weekend (April 26, 2013)
9) What features do you need in a motherboard?
The only thing I am looking for in a motherboard is for it to support the items listed below.
Windows 7 64 bit.
This is currently what I have planned:
I would appreciate any input on mistakes/alternatives before we actually go through with anything.
Thanks.
No.
1080p 23".
Windows 7 64 bit.
Processor - i5 3750k - $230
http://www.amazon.ca/Intel-Core-i5-...ssor+3.4+GHz+4+Core+LGA+1155+-+BX80637I53570K
Graphics Card - Radeon 7850 - $180
http://www.amazon.ca/Sapphire-Radeo...ie=UTF8&qid=1366671553&sr=8-1&keywords=hd7850
Motherboard - ASUS P8B75-M - $75
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131842
RAM - Corsair 2x4gb 1600mhz, 240pin - $80
http://www.amazon.ca/Corsair-Vengea...3M2A1600C9/dp/B004CRSM4I/ref=pd_bxgy_ce_img_b
SSD - Samsung 840 128gb - $110
http://www.amazon.ca/120GB-2-5-SATA...F8&qid=1366673364&sr=8-2&keywords=SAMSUNG+840
Hard Drive - Western Digital 500gb - $60
http://www.amazon.ca/Western-Digita...&keywords=western+digital+internal+hard+drive
Power Supply - Cool Master 500W - $50
http://www.amazon.ca/Cooler-Master-...366672831&sr=8-1-fkmr0&keywords=rosewill+500w
Total
$785
W/ Tax
$887
Thanks.
