I'd really like to know if there are any compatibility problems with bus speeds, memory, power, cooling and such. It won't be overclocked or used for gaming but will do a lot of video encoding and editing. Lots of Photoshop work with RAW images from cameras too. Cost is a major issue -- don't want to go any higher than the totals below. Also, quiet/cool is a big plus. Win XP pro for OS.
CPU: Intel E6750 194.00
MB: MSI P6N SLI Platinum 149.99
RAM: Patriot 2 X 1GB DDR2 800 PC2 6400 118.99 (-45 rebate)
VIDEO: MSI NX7600GS-T2D256E 78.99
VIDEO CAP/TV: AVerMedia M780 (AverTV Combo) 89.95
PSU: Zalman ZM450b 89.95
I'll be using an existing case, DVD-RW, and 3 hard drives, 2 of which are PATA, so that's why I went with the MSI board. I couldn't find any P35 or G33 boards with more than one ide connector.
Since there's no gaming, the vid card just needs to be something decent that doesn't produce a lot of noise and heat. The NX7600GS seemed like a good compromise, especially with the two DVIs.
I know very little about RAM other than to look for DDR2 800 PC2 6400 with lower timings, so I just relied on reviews at Newegg. Most of the RAM discussion is oriented toward overclocking, but I'd still like to do the best I can even without OC. Also considered OCZ and A-DATA.
For PSU, also considered a Corsair 520HX but not sure if it's needed or worth the extra $. Modular connections are nice though.
