fluffybunny
- Nov 29, 2007
Hey everyone,
I'm looking to build my first computer from parts, I have a lot of experience building computers from old computers and bits, but I have never picked all the parts and build it myself from scratch.
I am wanting it to be pretty cutting edge, but not too expensive. I also have primarily used intel, but based on some research and talking to a couple of friends they have recommended I go with the new AMD processor.
Primarily it is going to be a gaming pc and a HTPC. I know that doesn't make a whole lot of sense but I'm able to throw the computer in a closet so noise isn't a major factor.
Also due to funds, and price of the TB drives currently I am going to be doing the build in 2 phases.
Please give me some advice on parts and such.
My budget is around 1000-1400. If you could find something that I could spend a little bit less than, so I could go under the 1000 mark or anywhere around there would be nice too. (not including the video card which I already bought, look below)
Phase 1.
GIGABYTE GA-MA790FX-DS5
AMD Phenom 9500
OCZ 700W Power Supply (I am not sure about this one I have heard that the corsair is one of the best. Also I know normaly you dont need this much power but I think I will need it for Phase 2)
WD Raptor 150 GB
2 gb 1066 DDR2 RAM Crucial Ballistix(ive been told that the 1066 RAM will work better with the phenom processor something to do with the FSB and clock speed, I think. A better explanation would be helpful.)
Belkin Wireless G Card
Samsung SATA DVD Burner
8800GT video card(I bought it today due to the shortages ive been seeing and got it at a discount as well)
I cant decide between the Antec 900 case or the Cooler Master 690. Any recommendations? I get both at great deals with the discount.
If you figure the prices just use the newegg prices, and if it is in my budget with those than it will definitely be within budget with my employee discount.
Thanks A lot for any advice you can offer.
Phase 2
WD 160 GB SATA HD(Used for a direct mirror of the raptor drive)
2 of the WD TB drives( 1 is for storage the other is for a direct mirror of the storage drive)
Phase 2 is just primarily to get it more into the HTPC realm.
I will be using a Samsung LN-3251D as my monitor.(it is a 720P native 32 inch HDTV)
Any advice, recommendations, thoughts, or any other comments would be greatly appreciated.
Phase 1.
AMD Phenom 9500
WD Raptor 150 GB
Phase 2
