Hey guys,
A few quick questions about my Q6600 OC'ing results. Here is the basic make up of my system.
Asus P5Q-E
Q6600
G. Skill DDR2-800 2x2gb
Thermalright Ultima-90 heatsink
Thermaltake Armor+ case
6x 120mm Yate Loon medium speed fans and the 240mm Thermaltake window fan
OK, so now that that is out of the way. My CPU's VID is 1.3250, yeah I know I was bummed when I found this out. I was able to get up to 2.8GHz stable at 1.3000v. However, I had to bump up the voltage to 1.3750 just to get to 3.0GHz. Right now I am running 3.2GHz stable at 1.4000v (I tried 3.2 @ 1.3750, but prime95 was not stable). I also tried 3.4 @ 1.4v, but I got a lot of random restarts.
I will run more power through the CPU later when I have time, but my main question is about my idle and load temps. All these temps are with the side window on my case.
On idle my core temps read 45C, 38C, 38C, 40C (I will be lapping my Ultima-90 and my CPU in a couple of weeks and hopefully the temps will drop and even out). These idle temps seem kind of high for a Q6600 though.
Also, under load (Prime95) after about 20 minutes the temps are 69C, 62C, 62C, 63C. The 69C worries me, but I figure once I lap my CPU and heatsink my temps should drop down at least 5C.
Anyway, since I am currently at 1.4v on my CPU and I would like to try and get at least my OC to 3.8GHz, do you think the 0.1v that I have to work with until I reach the dreaded 1.5v limit will allow me to hit 3.8Ghz?
Thanks guys and I love this forum!
P.S. I will post screenshots later, not at my main rig right now.
Asus P5Q-E
Q6600
