Funky_Junk
- Oct 1, 2005
This is my first overclock so bear with me
Im running an Opteron 165 and a DFI Ultra-D. I had the FSB at 250 and everything ran fine. I then bumped the FSB up to 260. It booted into Windows fine but I got an error in Prime 95 after 1 minute. I had my OCZ memory at 260 as well. Do you think the problem lies in the memory or do you think I should bump up the voltage to the CPU? Or are there any other suggestions? Thanks.
