First hard line setup
Discussion in 'Water Cooling' started by sabrewolf732, Mar 25, 2019.
  1. sabrewolf732
    sabrewolf732 2[H]4U
    3,793
    Dec 6, 2004
    Hi.
    I've done a few watercooling loops in my history, I just started getting into pcs again the past year and a half after a 7 or 8 year hiatus.
    Specs:
    Ryzen 1600
    MSI B350 Tomahawk Arctic
    Geil pc3200
    MSI Seahawk 1080ti
    Seasonic 750w PSU
    lots of thermaltake riing fans
    HWLabs Nemesis GTS 420mm
    SC600 pump
    EKWB Supremacy MX
    Thermaltake view 31
    New parts weeee
    6cttaHGGCafO82shI9SiQ4Q81Ijfz5Ou0sfAJnuTtd-1m79hRrVU1qOxozbmdJWDm1Lo6rH_PP2RpQi4wd4ISVH70g=w2400.jpg
    it's a BIT TIGHT. Thermaltake says a 360mm rad is the largest rad to fit up front. Let's see about that.
    Yn6KRM-ePi_o1WSyKgSKBWWiOgnkyd1DkTdgjler7zh3WXR5dc6immx7-OPZs_TNyKavR3uCKJjToVGbF8MNmDDrtg=w2400.jpg
    some grinder work and we're good to go!
    aAkpBwddvtQq-3XY-P-PRFo6NFxJFe8cumJIpzfasug4AF_ycfNuenHf1VI915mj5l-5JVtmuY2Yrz1QC7QFCYd8fA=w2400.jpg
    Filling her up
    BnNI2dutE05raU4_VVvLSswexGnBkWQ2kAFet8cGVboTe8a8aolDfW9d4du412ggNWi6JtKpM5yvzD333w9tKbO9Bg=w2400.jpg
    good to go!
    fFratpn3LAvVruMsge4bkRq3g35G4NFrHnQZuAY4DKWAOGcIALhvFdQWNT2eOcv9eLBr-9Q_LaTXYnJ966Ehoky3jg=w2400.jpg
    In regards to temps, I was previously running the cpu on a modified swiftech 140mm AIO and the gpu was on a mcp655 with a black ice pro II. GPU temp has come down approx 15-17C (previously loading at 65ish C) and CPU was ~72ish at load and now loads at 62ish c.
    Solhokuten and Brian_B like this.
  2. Zarathustra[H]
    Zarathustra[H] Official Forum Curmudgeon
    27,642
    Oct 29, 2000
    Looks sharp.
    I've struggled with my comfort level with hardline tubing, as they seem to pull out of the fittings way too easily, whereas soft tubing is REALLY stuck in the compression fittings.
    On the flip side, I've had my swiveling bends leak in my build. If you bend your hardline right, you don't need to worry about that problem.
    How difficult was it to get the hardline bends right for a first timer?
  3. Dullard
    Dullard [H]ard|Gawd
    1,954
    Jun 28, 2012
    I like Primochill Revolvers, you can't pull them off the tube. But they are for 1/2" OD tube only - not 12mm - so I use Primochill tubing, too. Also no need to dress the end of the tube with the Revolvers, they seal with an o-ring squeezing down on the tube.
    I'll take some pics of my latest loop this evening if I get a chance, some pretty technical bends trying to stuff more rads in a case than it was designed for. Turned out sweet.
    Zarathustra[H] likes this.
  4. Zarathustra[H]
    27,642
    Oct 29, 2000
    Nice. What is the concern with mm dimension tubing?
    At least with soft tubing almost everything you can find in the U.S. is inch based, whereas the Europeans use mm dimesnions.
    Has this changes with hard tubes?
  5. sabrewolf732
    sabrewolf732 2[H]4U
    3,793
    Dec 6, 2004
    I was 50/50 on hard lines, but at this point I didn't really have anything else to upgrade (waiting for ryzen 3xxx).
    I was concerned that I could pull out the tubing with a bit of effort, but after getting everything in there's no way to pull it out/tubing to fall out.
    With the research I did everyone seemed to say to make sure you match fittings with tubing brand and to ensure you don't mix SAE with metric.
    Bending had a bit of a learning curve and I didn't order enough tubing (I thought I ordered enough extra to mess around with but I was wrong) so make sure you order an extra $10 to $20 worth.
    All in all it wasn't bad, I'd do it again but it was pretty time intensive.
  6. NoOther
    NoOther [H]ardness Supreme
    6,497
    May 14, 2008
    With also with soft tubing you can stretch the tubing a bit to fit the fitting, so changing out different components isn't as difficult, not to mention its cheap and easy to replace. Some of the reasons I never used hard tubing in my custom watercooling builds before. But hard tubing definitely looks nicer in my opinion. The good thing is, once you get a bit of experience, it gets a lot easier for future builds.
    sabrewolf732 likes this.
  7. Zarathustra[H]
    27,642
    Oct 29, 2000
    How much leeway is there in the fit of hard tubes? Do they have to be dead nuts on, or of you are slightly off, will coming in at a couple degree angle kill the whole fit, and have you starting that length of hardtube over again?
  8. sabrewolf732
    sabrewolf732 2[H]4U
    3,793
    Dec 6, 2004
    I found that there is a touch of leeway, at least with petg.
    I'd assume acrylic requires a higher degree of accuracy.
  9. NoOther
    6,497
    May 14, 2008
    Depends on what you are actually using for the hard tubes, as well as the pressure being applied by the angle. Some materials are more resilient/easy to make adjustments than others. You don't necessarily have to be dead nuts with some of them, but with the angle and pressure, there is a chance the seal is not perfect and it can leak or lead to leaking later on. Just like with flexible tubing, you usually want to cut your runs of tube longer than you expect, and then cut them back to size, this helps a bit with the adjustment. Spending more time in advance to get the angles and measurements ahead of time goes a long way.
  10. Dullard
    Dullard [H]ard|Gawd
    1,954
    Jun 28, 2012
    No concerns with mm themselves, it's just that 1/2" is 12.7mm, where some tube is 12mm - it won't work with the Primochill fittings designed for 1/2".
    You have to be pretty close, but the tubing is cheap and it's not hard to bend a tube that fits perfectly if you have the one that almost fit to go by. I recently swapped video cards in a hard tube build, had to make a new tube going to and from the video card. Draining the loop and refilling/bleeding it took a whole lot longer than bending two tubes, especially since I had the previous ones right there handy.
    Started a new thread instead of hijacking this one further.
    https://hardforum.com/threads/h-ardtube-loop.1979534/
    sabrewolf732 and Zarathustra[H] like this.
