Behyadehto
- Nov 8, 2011
Hello everyone. This is my first time attempting to make a custom computer. I have a decent understanding of what I need and I have made a list. I’m shooting for a powerful computer that can run Diablo III/SC2/BF3/Skyrim on the highest settings possible while still maintaining a high framerate. A friend of mine told me to check with this forum before I bought it, since it is a bit expensive, so please leave criticism and recommendations!
- Case: Steel ATX Full Tower
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16833189002
- Motherboard: Intel LGA 1366 X58 SATA 6GB
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16813121470
- Graphics Card (X2): EVGA GeForce GTX 580 Fermi 1536 MB 384-bit (I plan on running two of these)
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130587
- Power Supply: Corsair Pro Series Gold 850W
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139015
- Processor: Intel Core i7-980 3.33GHz LGA 1366 130W Six-Core
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116402
- RAM: 12GB (3 X 4GB) 240 PIN DDR3 SDRAM 2000 (PC3 16000)
- Hard Drive: Seagate Cheetah 15K.7 600GB 15000 RPM SAS 6GB/s
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148617
- Monitor: 27’’ LCD Monitor
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16824116455
- Disk Space: SATA DVD-ROM Drive Model Ihds118-04
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16827106276
- Sound Card: HT | Omega Claro Plus+ 7.1 Channels PCI Sound Card
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16829271003
- Network Card: Bigfoot Killer 2100 Gaming Network Card
Closing Thoughts:
- Am I missing any essential parts?
- Will I be able to SLI the graphics card?
- Do I have a large enough Power Supply?
- Does the case provide enough cooling fans(size or #) or do I need to buy better one?
- Is it possible for me to use Liquid Cooling with that setup?
- *Biggest question* I had an arguement with my friend over wether small RAM was better or Large, he ended up pointing me to the one I linked. However I originally was going to get a 32 GB RAM, with slower speed, which is better?
Thank you!
Closing Thoughts:
Thank you!
