First fully new PC build in 7 years
masteraleph
As noted, first fully new build in 7 years. I'd like to go in more of a SFF direction, so either Micro-ATX or Mini-ITX for case and motherboard.
Primarily Web browsing and word processing. Some gaming as well; DA3 when it comes out would be the most challenging game graphically. No FPSs.
$1600-2000, tax and shipping included.
NYC. Microcenter is a short drive; there are no Frys in the area.
Case, PSU, Motherboard, CPU, Memory, SSD, GPU, Monitor. Would prefer an SSD that's at least 512GB (1TB seems like it may be too expensive at the moment)
Reusing speakers, keyboard, and mouse (for now; it's a Logitech MX Revolution that will have to be replaced at some point because it's losing its ability to charge, but ok for now). Old copy of Windows 7 with a never used license.
6) Will you be overclocking?
No
That should be part of the recommendations. Would prefer a 27" 2560x1440 monitor, though I'd prefer something that can be gotten through a reputable seller, so probably leave out QNIX. My impression is that 4k really isn't there yet and may not be for some time; if I'm wrong, by all means let me know.
Within the next month. If there's something coming out imminently that I should delay a few weeks for, that's ok.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Would like to have some sort of onboard video just as a backup. Should have a digital out so I can easily hook it up to a receiver.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS?
Is it 32bit or 64bit?
Yes; as mentioned above, Windows 7 64bit.
How long is the drive to Microcenter?
Considering your budget, I would recommend waiting till the end of the month and ask for advice then as that's when Nvidia's 9xx series video cards should be hititng the market. Those will be faster than current Nvidia cards or at least as fast as current Nvidia cards but at a much lower price.
Cool then.
Well do you want to till the end of the month to buy the parts for the PC?
Cool then.
If there's likely to be a significant bump in price/performance, I'd be willing to do that. Most of the recommendations I see out there seem to be suggesting AMD due to better price/performance- is the expectation that the 9xx series is going to change that?
Yes from the limited info we can gather.
