First DIY Desktop Specs
evanb07
Motherboard: Biostar Hi - Fi A85W
CPU: AMD Yi dragon II X4 955
RAM: Kingston 8GB DDR3 1600
Harddrive: Seagate Barracuda 1TB 7,200 RPM 64MB
GPU: GALAXY GTX650
PSU: Red Star R500M
Is it suitable for playing games? Any suggestion?
I don't think that proc and motherboard are compatible. Where are you located?
I wouldn't consider it for playing games but since you didn't answer the sticky we have no clue on what games your playing, if you can spend more money on better parts, or what.
GPU: GALAXY GTX650
PSU: Red Star R500M
Please answer the sticky questions from the thread "ANSWER THESE QUESTIONS FIRST" so we can help you.
Though right off the bat, the CPU and motherboard are totally incompatible with one another: The X4 955 uses Socket AM3, which is both electrically and physically incompatible with the Socket FM2 of the A85W motherboard (which, by the way, is designed specifically for AMD's current generation APUs such as the A10-5800K).
What about BF3?
Now I'll ask what resolution?
Please answer the questions otherwise no matter what answer you give we're going to keep asking you something else. Until you answer them you're not going to get the information you seek.
