first build
spider0011
hi,
I would like some input for my first build its going to be built for gaming mostly starcraft 2 and diablo 3 when it comes out.
processor is AMD Phenom II X4 925
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103656
motherboard ASUS M4A785TD-M EVO AM3 AMD 785G
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131406
power supply CORSAIR HX Series CMPSU-850HX 850W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
case Antec Three Hundred
video card XFX HD-687A-ZNFC Radeon HD 6870
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150476
memory http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098&cm_re=20-231-_-20-231-098-_-Product
havent decided on hard drive yet also thinking about using my rca 42 tv but its only 720p so i dont know if im going to use it or a monitor yet.
price I want to stay close to 1000
thanks for any input
gaming and browsing
2) What's your budget? Are tax and shipping included ?
around 1000
3) Where do you live?
us no I do not have a frys or microcenter, I will be buying everything on newegg
cpu, ram, case, power supply, video card, hard drive, optical, and monitor
none
6) Will you be overclocking?
maybe
24
within the next month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
crossfire
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit
or 64bit?
yes
Awesome that helps alot.. For clairification though
3) If you dont want to give your location can you at least tell us if you have a Fry's or Microcenter near by. That is the primary reason for that question since often there deals way surpass the nets.
4/5) HDD & Optical I assume will need to be included
7) Recommendations for the rest of the system will vary greatly depending on this answer since there is a huge difference hardware to run 720p & 1080p (or 1920x1200).
8) Sandy bridge is coming out in another week or so so if your not building for a few weeks you might want to repost later since our recommendations will vary based on street pricing & reviews of SB that we wont see for another week or so. However if your in a hurry you have the budget as it is to do a pretty decent system.
and yes im going to need a hard drive and optical
I am pretty sure im going to get a monitor prolly a 24 inch
and sandy bridge is intel? I want to use amd for some reason
Ok.. No point in waiting then really.. I will post back with something shortly.
Edit: Also is the monitor included within budget? how about OS?
245 ASUS M4A87TD/USB3 AM3 AMD 870 + AMD Phenom II X6 1055T
150 Microsoft Windows 7 Home Premium 64-bit + COOLER MASTER HAF 912
300 GIGABYTE GV-R695D5-2GD-B Radeon HD 6950 2GB
85 G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
90 SeaSonic M12II 620 Bronze
70 SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM
17 SAMSUNG Black 22X DVD+R
33 CORSAIR CAFA50 120mm CPU Cooler
995.22 Shipped total.
spider0011, if you can't take advantage of bastage's build today, come back and revisit this thread in a couple of weeks.
By then, Sandy Bridge should be out in full force and NewEgg should start offering some good combo deals that we could take advantage of.
whats wrong with the stuff I had picked out
The only component on your list that I would not recomend is the Antec 300 & thats simply that there are more roomy & easier to work in cases for the money.. The rest of what you picked out is fine for a gaming system, But you said
So I spec'd you the best system I could find for 1000 dollars.
So If you want a lower end system I can definitely redo the list & use most of the parts, But the Case (explained above), PSU (way more then needed, so no point on wasting money on it) and memory (not compatible with motherboard) wouldn't be used.
I recommend bastage's build, as it would be similar to what I would recommend for you.
Ok I will look at the build you tecmmand more I just was wondering if parts I want where bad parts or what
You didn't have any bad parts in your build, but with the information that you gave us in your OP, you didn't have the best setup available for your budget. Plus, since you're not using a 1080p resolution, the video card and power supply were overkill for your needs.
Not really bad parts at all.. Just the cost doesn't justify the performance.. The only BIG issue I saw with what you listed is a DDR3 right with DDR2 memory spec'd.
To sum it up on a piece by piece basis here is why I recommended different parts. The x6 better performance then the x4 obviously, Motherboard has a newer higher end chipset, PSU is lower watage, but higher quality, Case has room for larger video cards as even the 6870 you spec'd would be pushing the power connectors inside of the drive bays of the antec 300 & lastly I spec'd the next step up in AMD graphics lineup as you had the budget to get the extra performance.
Memory wise I also spec'd 8gb DDR3 instead of 2gb of ddr2
Thanks for the help few more questions, i want to use a 24 inch monitor any recommendations, also why do you pick a samsung hd instead of western digital
The Samsung he picked is substantially faster than the Western Digital you had picked.
You want monitor recommendations? Or other part recommendations with a 24" monitor in mind? Bastage's current build would handle a 24" LCD just fine. I'll come back with a few monitor recommendations in a few minutes here.
What kind of budget for the display are you talking? Is color accuracy important to you? Will you be sitting directly in front of the display 99% of the time?
after getting home and looking at the build you posted, I have a few more questions. The cooler how hard is it to install, and the hard drive do you have any more recommendations? a few more bucks wont kill me lol.
thanks again
thanks again
Installation is pretty straight forward.
As for HDD recommendation, how much more you talking about. Beyond an f3 my recommendation would be a 2nd f3 or an SSD if your budget allowed.
No, you don't need a sound card, onboard sound has come a long way, unless you have a really nice set of speakers onboard sound will be just fine.
The ram in the OP's first post is DDR2, and the board he chose is DDR3. Just throwing it out there. No new build should be using DDR2 anymore.
The OP's processor is going to be a bit weak for gaming, unless it is overclocked. I suggest getting a Black Edition or a hex core, if you can spring for it. Also, 850w is overkill for that system, even with crossfire 6870's. Bump down to 650-700ish.
Yes, the Gigabyte and XFX cards use the same GPU.
I have a few questions for you:
Are you considering buying a new monitor within the next six months? Do you have one in mind?
Which games are you (planning on) playing? At what level of visual quality?
Outside of gaming or "browsing," what will you use this system for?
Assuming that good deals are available now (though they probably won't arrive for another week or two), would you prefer building your system sooner or later?
I have decided that im going to use a monitor instead of my tv.
so far diablo 3 and starcraft and prolly some shooters since thats what i mostly play on xbox.
photos from my dslr.
its going to be later I am going to buy one part a week hopefully.
When are you buying the new monitor?
How much cash do you have on hand right now? (I recommend that you buy as much as possible in as few "trips" as possible.)
monitor will be bought with build I do not have one because im using a laptop now.
prolly200-300 next week
I'll revisit this thread next week. I want to wait for NewEgg's better combo deals to arrive before I make my recommendations to you.
Are you willing to raise your budget (like, say, to around $1200 or $1300) to cover your system and the monitor?
After listening input and getting help with friend here is what I have.
Posting on phone so no links.
Case 300
Proc and phenom II x4 965 black edition 3.4
Memory gskill sniper 8gb 2x4 DDR 3 1333
Mobo Asus m4a88t-v
Corsair 850 hx power supply
Samsung b2430h monitor
Hdd western digital caviar black wd1002faex
Video card xfx hd 6950
- Ditch the Antec 300 as it is not worth $60. This case is a far better choice for the money:
$60 - Cooler Master HAF 912 RC-912-KKN1 ATX Case
- Ditch the Caviar Black WD1002faex as this Samsung drive is just as fast yet is cheaper:
$70 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
- That PSU is stupid overkill for that setup. You'll be fine with a quality 650W or 750W for extra headroom.
Gonna wait with Tiraides as well on the recommending a full list.
+1. also consider the NZXT cases. You can certainly find nicer layouts, cable management, and features for the same price.
Guys, the OP mentioned in post #3 that he planned on using CrossFire. The question that I have is: What games are you playing that require CrossFire, now or in the future?
