First Build What u Guys think!
civictyper16
Hey guys this is gonna be my first build ever.I am gonna do heavy gaming,Hd encoding,and some 3d modeling.Im working with 1,200$
Seagate Barracuda 7200.10 250GB = 67$
http://www.newegg.com/Product/Product.asp?item=N82E16822148142
Evga GeForce 8800GTS 640MB =409$
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130080
G.SKILL 2GB DDR2 800 (PC2 6400) =160$
http://www.newegg.com/Product/Product.asp?item=N82E16820231065
EVGA 122-CK-NF68-A1 LGA 775 NVIDIA nForce 680i =240$
http://www.newegg.com/Product/Product.asp?item=N82E16813188013
Intel Core 2 Duo E4300= 121$
http://www.newegg.com/Product/Product.asp?item=N82E16819115013
HP W2007 20.1” Widescreen Monitor=250$
http://www.circuitcity.com/ssm/HP-20-1-Widescreen-Monitor-W2007/sem/rpsm/oid/176650/catOid/-12965/rpem/ccd/productDetail.do
LITE-ON Black SATA DVD Burner with LightScribe - OEM = 41$
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106073
Price 1,288$
What u guys think i am a little over budget and im still missing a hsf i plan to overlock for my first time also.Newegg is back ordered on tuniq , Scythe and thermalright.
Looks pretty sweet. I personally would have gone with a bigger hard drive, but nice vid card :D I have one and I love it. Also, for a heatsink and fan, check www.frozencpu.com <-----the have tons and good customer service from what I hear.
Are you planning to overclock?
9 * 400 = 3.6Ghz... We all know the E4300 (or any allendale core, for that matter) can't reach that high (unless the OC gods shine down on you), so save your money and go for some DDR2-667 ram instead. The cheapest kit is around $85... almost half price of the kit you chose! Spend the leftover cash on an AC F7Pro instead, since the E4300 can only reach around 3Ghz &#177; 200Mhz. If you want to stick with newegg, go with the Scythe Ninja instead, as they overpriced their listing of the AC F7Pro.
Here, some Super Talent DDR2-667 for $90:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820609219
Then you can OC to 9*333=3Ghz... and if you want to go a little higher, that STT ram can OC a bit, too!
BTW, I like the Dell 20" over the HP, because it has a better stand, imo (unless HP changed their stands). Theres a Sceptre 22" at the egg for $260AR, btw. I'd go for that instead, lol.
I was thinking of getting the Sceptre 22" seemed like a hell of a deal but theres been alot of reviews saying the dvi stops working after a couple months.
for a heatsink check out www.svc.com
they usually have competitive prices on thermalrights and tuniqs. and instead of going with that ac freezer pro 7, i would pick up a thermalright ultra-90 and a panaflo for a couple dollars more.
You could most likely OC the E4300 to 3Ghz on stock cooling, though.
What u guys think about the monitor any better choices.
better? better price-wise? better quality-wise? better picture-wise? better gaming-wise? what are you asking for? there will always be a better choice.
I want the best for under 300$ and it has to be 20" or more.You guys havent judged much on the build i guess its pretty good then.
9 * 400 = 3.6Ghz... We all know the E4300 (or any allendale core, for that matter) can't reach that high (unless the OC gods shine down on you), so save your money and go for some DDR2-667 ram instead. The cheapest kit is around $85... almost half price of the kit you chose! Spend the leftover cash on an AC F7Pro instead, since the E4300 can only reach around 3Ghz ± 200Mhz. If you want to stick with newegg, go with the Scythe Ninja instead, as they overpriced their listing of the AC F7Pro.
If you didn't get the message, GET DDR2-667 RAM INSTEAD OF DDR2-800, and get a better HSF with the money saved.
Just go with the Sceptre, since you don't know what it is you're looking for in a monitor except size and price.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811103010
XCLIO A380BK Fully Black High Gloss Finish SECC 1.0mm thickness ATX Mid Tower Computer Case
99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115016
E6420
196.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131142
P5N SLI
139.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814122018
Leadtek WinFast PX8800 GTS TDH GeForce 8800GTS 640MB 320-bit GDDR3 PCI Express x16
324.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822144422
Seagate 250gb-16mb 7200rpm
59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827131038
SONY DVD/CD/DVD R/CD R
29.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16824252008
CHIMEI CMV 221D-NBC Black 22" 5ms DVI Widescreen LCD Monitor 330 cd/m2 800:1
249.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118223
ZALMAN CNPS9500 LED 92mm 2 Ball Cooling Fan with Heatsink
53.99
$1265
Woot.
