First build since 2002, suggestions welcome
Quezor
I haven't upgraded since 2002 so my current comp is quite ancient (it's a prebuilt hp w/ athlon xp 2200 :eek:). Decided to go SFF as I would like to save space and I'd need the portability. Will be used mostly for gaming and some office apps at 1680×1050.
Case: Qmicra v2
MB: DFI LP P45-T2RS
GPU: HD 4870
CPU: Q6600 (want to OC to 3.0 at least)
CPU HSF: Thermalright Ultima-90 + Scythe Kama 92mm PWM
Case fans: 2x Nexus 120mm (side) + 1x Noctua 120mm (back)
RAM: G Skill 4GB (2 x 2GB) 240-Pin DDR2 1000
PSU: Corsair 620HX
HD: Western Digital Caviar WD6400AAKS 640GB
DVD: LG 20X DVD Burner GH20NS15
OS: Vista Home Premium 64bit
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=8237731
Heard very good things about the Qmicra case: its ability to fit larger graphics cards and excellent cooling and since I'll plan to OC this is a plus.
The 4870 seems to be the best bang for the buck right now; I initially considered a 4850 but it may not last as long as I'd like.
Going with a Q6600 due to its low cost and ease of OC'ing.
I was initially shooting for a budget of $1200 but it looks like it will be over $1300 considering the case cost.
Also I won't be buying everything at newegg despite putting them on my wishlist. I'll be getting the 4870 at best buy since it'll be $250 this coming week.
Any suggestions are welcome.
did you pick that mobo because its micro atx?
Well if you look at his case choice (Qmicra v2) and what he said, yes he did choose the Crossfire capable motherboard since it was mATX. Also, HD4870 CF is total overkill for 1680x1050 anyway. So the Crossfire upgrade point is a bit moot.
Anyway, OP, your rig looks good to me. Just be sure to get the Corsair PSU from amazon.com, buy.com, provantage,com or zipzoomfly.com for lower prices.
I may go with the 750TX instead as there is a newegg combo deal with the Q6600 (both for $275 vs. $355 if I get the 620HX). Modular isn't that important for me as I will have an empty drive bay to store the extra wiring.
