General Programming, Gamming (FPS, and WOW) and Work, and some Video editing, Game Recording (from Xbox and Computer Screen)
Less than $2,400
US, WI
CPU, CPU Fan, RAM, Motherboard, PSU, HDD, Case, GPU(not now tho), Thinking of a SSD (250GB)
N/A - Interface parts (Keyboard, Monitor, Mouse)
6) Will you be overclocking?
If it possible with the setup I have
7) 7) What is the max resolution of your monitor? What size is it?
1920x1080
2 - 3 Months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
SLI, USB 3.0, Sata 6GB/s, onboard video (optional)
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Don't have one yet but will when buying parts (Win 7 64bit)
CPU - Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I72600K
Motherboard - ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
CPU Fan - Noctua NH-D14 120mm & 140mm SSO CPU Cooler
HDD - Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
RAM - G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL10D-16GBXL
maybe a 4 x 4GB rather than 4 x 8GB
Case - Rosewill THOR V2 Gaming ATX Full Tower Computer Case, support up to E-ATX / XL-ATX, come with Four Fans - 1 x Front Red LED 230mm Fan, 1 x Top 230mm Fan, 1 x Side 230mm Fan, 1 x Rear 140mm Fan
PSU - ?????? COOLER MASTER GX Series RS650-ACAAE3-US 650W ATX12V v2.31 80 PLUS Certified Active PFC Power Supply ??????
So ya... this is what I think I'll like to get but got a question about the CPU fan and case and RAM spacing --- Will the CPU fan listed fit on my motherboard with 4 sticks of ram and also fit in the case?
and this is going to be my first computer build
EDIT: i added links to each components
Less than $2,400
US, WI
1920x1080
2 - 3 Months
