First Build Need some Help!
civictyper16
Hello guys i am trying to build a pc no higher then 1,100.I really don't know much about overclocking or computers in general but i really want to learn.I have been researching a lot on hardforum any recommendations will be really helpful.I'm also really hesitant to what memory to buy i don't know anything timings and latency???
ASUS P5N-E SLI=$139.00
http://www.newegg.com/Product/Product.asp?item=N82E16813131142
Intel Core 2 Duo E6600=$316.00
http://www.newegg.com/Product/Product.asp?item=N82E16819115003
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800=$209.99
http://www.newegg.com/Product/Product.asp?item=N82E16820231087
EVGA GeForce 7950GT 512MB 256-bit GDDR3 PCI Express x16 HDCP KO Superclocked=$285.99
http://www.newegg.com/Product/Product.asp?item=N82E16814130066
Western Digital Caviar SE WD2500JS 250GB 7200 RPM=$69.99
http://www.newegg.com/Product/Product.asp?item=N82E16822144417
LITE-ON Black 18X DVD+R 8X DVD+RW 8X DVD+R DL 18X=$31.99.
http://www.newegg.com/Product/Product.asp?Item=N82E16827106043
ARCTIC COOLING Freezer 7 Pro=$49.99
http://www.newegg.com/Product/Product.asp?Item=N82E16835186134
Price=1,103.94
Do you need a COMPLETE PC or are you swapping over some parts from another build? If you need a complete PC then you need a case, power supply, and optical drive(s). If you are swapping parts over from another build then you might want to state what parts they are (brand name and model).
I completely forgot to mention I already own a power supply and a case.These items where purchased a while ago.I think i should have bought a better power supply do u think it will be sufficient to power this rig.I'm gonna use it for mostly gaming and 3d modeling.I was wondering should i get the E4300 allendale instead and get a DX10 Card?
Aeroengine 2
http://www.aerocool.us/p-case/aeroengine2/aeroengine2.htm
Ultra X-Finity 600 Watt
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1273340&CatId=1483
Read the review for the power supply you bought: http://www.jonnyguru.com/review_details.php?id=34
Judge for yourself if you want to buy a new PSU.
Oh and go for the E4300 and the 8800GTS. You can easily overclock the E4300 to the E6600's speed. The extra 2MB cache on the E6600 is only a 5-10% performance increase.
So just to reiterate, buy the E4300 and the nVidia 8800GTS. It'll be a huge gaming beast.
I recommend the Corsair HX 520 over the Xfinity600. It's $106 at zipzoomfly, shipped.
