Hey guys, I'm finally starting to realize that my current P4C 3.0 system from 2003 just doesn't cut it anymore. Its had a long and very admirable run but its time to move on to something new.
1) What will you be doing with this PC?
The main use will be music production with Ableton Live 8, along with VSTs. Perhaps some other DAWs in the future as well. Secondary use will be gaming. Also, general web browsing, etc.
2) What's your budget?
Budget is around $1000. This is somewhat flexible though, if I can achieve what I want for a little less, great.....if i need to go over by a little bit, its not the end of the world.
3) Where do you live?
Near Boston, MA. I live close enough to a Microcenter, if that matters.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU, motherboard, memory, case(I could reuse my current ATX case if I need to save some money, though), video card, power supply(probably, see below), SSD. I also need to get a good sound card, but this is NOT included in the $1000 budget.
I currently have a 450 watt Rosewill power supply, model number RD450-2DB. I think its from around 2005 or 2006. I am assuming I am not going to be able to reuse this, but if i can, great. Also I have several IDE hard drives that I use for storage, as well as some external USB ones. And IDE dvd burner as well.
6) Will you be overclocking?
maybe, but probably not right away.
Right now I use dual 1280 x 1024 LCDs. Will probably get something better eventually.
Probably sometime in early/mid July.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Firewire, USB 3.0, and onboard wifi would all be nice but are not absolutely needed. Probably will not be doing a dual video card setup.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Already have windows 7
Some more things:
I would like this machine to be relatively quite. Doesn't have to be silent, I would just like to get it as quiet as possible while still maintaining an adequate level of cooling/performance. I have also been considering micro ATX motherboards as they seem to suit my needs, and the Antec p180 mATX case has caught my eye, but I am not dead set on this. I definitely would like the case to be small or medium sized... no full towers.
I am pretty sure I want an i7 CPU, or maybe an i5 750 (I am open to AMD cpus but these intel's seem to be the best buy at the moment). I am kind of having a difficult time choosing between LGA 1366 and LGA 1156, though.
for a video card, I have been looking at a Radeon 5770, and perhaps something better if there ends up being room in my budget.
As for the SSD... I am somewhat clueless in what to look for. I have seen the Intel X25M G2 80GB recommended a lot online, but its quite pricey. Is it worth it, or could I go for something a bit cheaper?
Looking for any input you guys might have. Thank you!
Some more things:
