First build in progress... Help!
torrey.smith
I Love the Cock - Please PM Me
Hey Guys,
I've put all of the components together in the following order, except for one of the graphics cards which I will do later.
Antec P180
Thermaltake 1200W
4X Maxtor 500 GB 16MB SATA
2X Lite-On DVD
ASUS Striker Extreme Mobo
Q6600 w/stock cooler (for now)
4X 2GB Wintec DDR2 800
Sound card that came with Mobo
MSI Liquid cooled OC 8800 GTX
Remaining misc. connections
Logitech gaming keyboard
Razor DeathAdder mouse
Dell 3007WFP
This was done per the nice manual that came with the Mobo. Next, I crossed my fingers, and turned it on.
The display was weird- it was fuzzy and yellow, and I noticed that it would fluctuate when I accidentaly (and lightly) bumped the 8800 GTX card.
The "Republic of Gamers" startup window showed up, and I went into BIOS. The HDDs and DVDs were detected, and I enabled RAID. Then I exited and set up a RAID 0+1 configuration. Then I put in the Vista 64 disc and rebooted.
It showed the startup window and then said "windows is loading files." After the bar was completed (a few minutes), the screen went to an error message that said it had not found a file:
\windows\system32\Drivers\Ntfs.sys
I was confused. I rebooted and disabled RAID, and retried. I got another error message:
\windows\system32\Boot\winload.exe not found.
I have tried it several more times, to no avail. I was expecting/hoping that a Windows install would begin.
One other thing is that one of my DVD drives, while recognized in BIOS, does not seem to work in the sense that the Windows disc does not start "loading files" when I use it. I have confirmed that it is connected just like the other DVD drive.
Should I try installing XP? Maybe there are too many factors stacked up right now?
Thoughts?
- Google, download, burn and run Memtest+ to rule out any RAM problems. Run it for at least 3 hours or 24 hours max.
- Google, download, burn and run Drive Fitness Test to rule out any hard drive problems.
- Try installing with a different CD/DVD drive. In fact try to use a PATA drive. There have been a few cases where Xp/Vista refuse to install with an SATA CD/DVD drive.
- Try a different Vista install disc if possible.
Also, this is going to sound a little weird, but I would pull my video card out and make sure there is not any foreign material embedded in the pci-e slot, like a small piece of packing foam peanut(s).. LOL. Yes, it happened to me.. LMAO. I did encounter the blurriness effect on a DFI lanparty and a 7800gtx when I orginally built it. Also, ensure that the 6 pin power plug is fully seated into the 8800gtx card. As for the other errors, I can't say..
I agree with officeremartinez, I think it's related to your video card... double check and make sure it's seated correctly.....
EDIT... nice rig too...
Thanks Guys! I will do these things and report back. It makes me feel a lot better having things that I can do!
OK, I ran Memtest and Drive Fitness Test, and they appeared to be normal.
I moved the 8800 GTX card from the first PCI-E slot to the second, and the system would not start. The fans would kick up to speed but then nothing else would happen, while the fans slowed to stop. The LCD screen on the back of the Mobo said "CPU INI."
I put the 8800 GTX card back into the first slot and the system started, but with the same weird yellowish plaid display.
Then I threw in the Vista 64 disc again, but this time it would say "windows is loading files" like usual, and then the screen would go blank, the system would restart and then freeze.
Also, the first DVD drive is definitely not working as installed, as neither Memtest or the Drive test would boot from that drive.
It works! Many props to ASUS tech support on this one.
They suggested that I try the other video card, and that immediately solved the display issues. I'll be exchanging the bad one. They also said that Wintec RAM is low-quality, and that having all 8 GB installed could be causing windows to fail to load into memory successfully, halting the install.
I removed all but one DIMM and it booted into the Vista install on the first try. I’ll be returning the RAM and purchasing some high-quality stuff. Recommendations, anyone?
The stories of long waits with blank screens during the install are true; don’t be discouraged!
My RAID 0+1 array has worked perfectly throughout the install phase, and now into the installation of drivers and updates. Vista sees it as a 1 TB single drive, but it is actually 4 Maxtor HDDs.
I still need to see if one of my SATA Lite-On optical drives is malfunctioning, but at this point it may work- we’ll see.
Thanks everybody up to this point, and I will be posting pics of the build soon.
Good for you.. I knew it had to be an issue with the graphics card. So, congrats on solving that issue. As for ram, the prices have really dropped in the past month. So, buying some quality ram right now should be relatively painless. There are several good brands of ram out there right now. Like you, I am on Vista. Personally, I run 4 gigs of Corsair Dominator PC2 8500C5D ram (1066mhz). If you are considering buying any ram, I would NOT go lower than 1066mhz rated ram. With the impending DDR3 release, I would stick with 1066mhz or higher (since you are running the Asus Striker, that motherboard is very capable).
I have RMAd the Wintec ram, after the ASUS support guy said that it was low quality. I checked for ram at higher than 800 MHz, but it was over $600 per 2x2GB set, and I need two of those for the 8GB total.
I purchased 8GB of OCZ High Performance DDR2 800 memory. I hope that it will be sufficient for now.
A new problem cropped up: I had Vista 64 running smoothly, and going through all the updates. I took out the one 2GB stick of Wintec that I had been running and put all 4 sticks of the OCZ in. Windows failed to load. I took out three sticks, and it failed again. I put back the Wintec and it failed in the same way.
I rebuilt the RAID array and re-installed, but after the first of several restarts during the install, it failed to load!
I'm a little confused here.
