First build for friend - $700
Nightcast
[H]ere for the Blow!
My buddy is looking to build his first gaming computer.
Gaming SC2, BF3, web browsing
$700 No and no
Michigan, Microcenter sub 20 miles.
4) What exact parts do you need for that budget? CPU, RAM, case, etc.
CPU, MB, Ram, HDD, DVD drive, GPU, PSU, Case,, keyboard and mouse.
Nothing.
6) Will you be overclocking?
No
1440x900 19 ws"
Within a month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
SLI would be nice for later down the road and SATA 6gb
Win 7 64bit Pro
Keyboad and mouse arent really a big deal. He is kinda stuck on a i5 build but without actually looking im thinking it might not be in the budget with him needing everything.
I recommend this setup:
$120 - Intel Core i3-2100
$55 - Biostar H61MGC LGA 1155 Intel H61 mATX Motherboard
$40 - G.Skill Value Series F3-10666CL9D-8GBNT 2 x 4GB DDR3 1333 RAM
$167 - XFX HD-687A-ZHFC Radeon HD 6870 1GB PCI-E Video Card
$70 - Western Digital WD5000AAKX 500GB 7200RPM SATA 3.0Gb/s Hard Drive
$18 - LG GH24NS90B DVD Burner
$64 - Antec NEO ECO 520C 520W PSU
$50 - NZXT Source 210 Elite White with Black Front Trim ATX Case
$95 - Acer S201HLbd Black 20" DVI Widescreen LCD Monitor
$15 - Microsoft USB Keyboard
$9 - Rosewil Optical USB Mouse
Total: $703 shipped
Thank you. After a little searching I found a old 19 LCD he can have either that or he says he will use his 32" tv.
If that's the case, then swap out the i3-2100 for
$209.99 - Intel Core i5-3550
If you get it before the end of 8/15 then use promo code EMCNBNA39 to get an additional $10 off. Since you wont be needing an LCD. No point really in upgrading the GPU, since at the resolution he'll be playing at wont notice much of a difference with a faster GPU.
