First Build - any comments/suggestions?
Dalai
Hi all, new here and looking for any advice. I'm about to build my first computer, and wanted to run my build list by you guys first.
Gaming and Photoshop
$1500 max
3) Where do you live?
California
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
(see list below)
5) If reusing any parts, what parts will you be reusing? Please be especially specific
about the power supply. List make and model.
Only reusing an old hard drive
6) Will you be overclocking?
Probably not
30'' 2560x1600
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
crossfire in the future possibly
10) Do you already have a legit and reusable/transferable OS key/license?
Nope!
So here is the current build list:
Case
Antec Three Hundred Gaming Case External 3 X 5.25; Internal 6 X 3.5 2*Usb2.0
http://www.amazon.com/exec/obidos/t...t_shr?_encoding=UTF8&m=ATVPDKIKX0DER&v=glance
PSU
Corsair CMPSU-750TX 750-Watt TX Series
Motherboard
Asus P6TSE Core i7 / Intel X58/ DDR3/ CrossFireX/ A&GbE/ ATX Motherboard
Video Card
XFX RADEON HD 5870 1 GB DDR5 PCI Express Card HD587AZNF9
CPU
Intel Core i7 920 2.66GHz 8M L3 Cache
RAM x2
Corsair TR3X6G1600C9 XMS3 6 GB 3 X 2 GB PC3-12800 1600MHz 240-Pin DDR3
Hard Drive
Western Digital Caviar Black 1 TB
http://www.amazon.com/Western-Digit...9?ie=UTF8&s=electronics&qid=1254356552&sr=1-9
I'm pretty confident with this build, but please let me know if you guys have any suggestions. Thanks!
everything looks good but note, for every video card installed. You will lose hard drive slot in Antec 300.
Looks good to me. I was gonna recommend cheaper combos from Newegg then saw that you were in California. So never mind :)
Do you happen to live near a Microcenter?
Thanks for your replies - Danny, I believe the nearest microcenter is about an hour away, so looks like I'm sticking with Amazon for everything but the video card. Time to order, wish me luck!
