First AMD64 Overclock
Keetha
It is 9.5 x 240 = 2280 and voltage of 1.65.
Ram is running at 5:6 so it is 190 with timings of 2-3-2-5
This is with a stock cooler and 2ghz default. It's for someone else, so I didn't push too hard so it will be 100% stable. It's on the Asus K8N with a SATA drive. According to Anandtech, using a SATA drive on this motherboard limits the OC severly. It idles around 39C and maxes at 51C under full load. Just looking for any opinions or suggestions or something :)
Thanx!
dang thats quite a low multiplier you got there good job on high fsb... i wish my memory could handle high fsb
SidewinderX said:
if you notice, his memory is 5:6 not 1:1
didnt notice that... good point.. i wish my memory could go past 200 mhtz cas2.5.. but i think the benefits of fsb is less then cas 2.5
