Firewire and the NF7S
Glitchwolf
This board has been running smooth for so long, I highly recommend it to anyone looking for a good AMD board.
Anyways, that isn't what this thread is about. I got an iPod the other day and I knew Firewire would be the best option for transfering music between Computer/iPod. So I put the metal bracket thinger in my computer, hook the two red connectors into the IEEE slots and the one blue on into the USB slots, and I get nothing.
It says in the manuel that I don't need to install any drivers, it doesn't tell me anything about postion either. I lined up the holes with the pins, duh.
I've got all the iPod software installed so that isn't the problem.
Anyone got any ideas?
Thanks.
Is your controller enabled in the BIOS? Does Windows recognize it? I have a file called "nForce2-1394_filter.zip" that's some "Filter driver," but I've never tried firewire on my board, so I don't even remember what that file is for or if it's needed, haha..
I went into BIOS and I found something called IEEE and it was enabled, so that isn't the problem.
It says I don't need any drivers in the manuel.
